Question about LaCie (301074) 80 GB Hard Drive
Lacie hard drive won't turn on
My Lacie d2 quadra just won't turn on.  I need the data out!  Please, can someone help me to solve this?
My 1TB Lacie suddenly won't power up (no sound, no blue light). It turned out that I might have worn out the on/off switch over the seldom-use 4 years of usage. I push and flip the switch multiple times, and the Lacie came back to live and mount normally. I will just leave it at the On setting and simply pull the power cord when i want to switch it off.
Obviously, Lacie failed to do QA on the on/off switch because my 4 years usage did not totalled to more than 10 on/off per month.
Posted on Jun 13, 2012
5 Suggested Answers
ejkudelka
  • 1188 Answers
SOURCE: My Lacie Hard Drive only
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Posted on Aug 05, 2011
bob_computer
  • 3153 Answers
SOURCE: My lacie d2 quadra 500 gb hard drive does not
I can offer some simple advice based on windows PC's for these types of hard drives and that is contained here
http://www.fixya.com/support/r4247716-usb_device
It assumes USB type connection but I have also had firewire and e-sata issues with the cables supplied so tend to buy the ones that have the lock on them as these tend to be a little better
Bob
Posted on Oct 14, 2010
SOURCE: deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Posted on Apr 06, 2009
  • 242 Answers
SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Help please -LaCie D2 Quadra
Take a look at this link and see if it helps -
http://homepage.ntlworld.com/allcam/pc2mac.html
Jan 07, 2008 | LaCie D2 Extreme 300 GB Hard Drive
LaCie (301074) 80 GB Hard Drive Logo
3,139 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
