Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Ice dispenser and water dispenser not working, also dispenser light not working ice and water dispenser won't work, light won't work
    President:
  • KitchenAid Master
  • 2,651 Answers
Ouch!!!, heres what i wouldlook for, foirst off remove the lower kickplate, from ther youll see a wire harness leading from the bottom of the door leading to a multi plug right in the front of machine, unplug this. from there i would want to check the individual wires coming from the door. a natural pinch point is created from opening and closing the door and results in ripping of the wires.. youll need to cut the spider like harness covering they use to protect wires, im thinkn a few of those wires are definalty sheared..bad part is the only fix for this as perwhirlpool ios replace teh door( $500+) if this is the case, yhou cannot wire nut the connections( not enought room, you can solderthewires or i have had some sucesse in using what they call "**** connectors" to reattach.. just leave the harness unplugged till rectified( dont want to "short " anythin out
Posted on Mar 09, 2009
GE refrigarator ice and water
Looks good to me! What is the model number? I thought I was going to get a demo! Sea Breeze
Apr 26, 2013 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water won't dispense but ice maker works
Most likely the valve has failed. Usually located in the back of the refrigerator, near the bottom - otherwise, follow your water line (feed from the house water supply).
Aug 02, 2012 | Roper RS22AQXKQ Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
199 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
