Question about RCA RP5430 Clock Radio
RCA atomic clock radio didn't reset to DST
The RCA atomic clock radio I bought for my parents didn't change to
DST. What do I do to set the clock to DST.
Thanks
  • johnsjames Apr 21, 2009
    My clock did not switch to DST, and so it is now an hour behind. There is no button for manual setting of time. Help!
    Problem Solver:
It is possible that the clock has old computer software code. If I recall the government changed Daylight Savings start up several weeks a few years. ago. My clock did not update also.
Posted on Mar 09, 2009
    Problem Solver:
  • 6 Answers
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
Our atomic weatherstation/clock has never reset to DST
I had the same problem with my atomic clock. Had to move it to a clear area, one without obstrucions. It set itself almost instantly
May 26, 2011 | La Crosse Radio Controlled Atomic Clock
How do I change the time one hour ahead for an RP5430A model clock radio?
Slide the Wake 1/Wake2/Clock switch to the Clock position. Then press the forward button to advance the clock by the needed amount of time. Then slide the switch back to the side with the key icon.
If you set the DST switch to ON, you can move the time zone switch to one time zone further east for a few weeks until the DST change in the program takes effect. Then move the time zone switch back to your current time zone. (Repeat this in the fall to correct for the later change in DST again). The exact length of time between when DST starts and ends versus when the clock will change the program will depend on when the clock was manufactured. Clocks built after July 2006 should have the correct DST programs. Clocks from earlier have a much shorter period of DST (April through Oct).
I hope this helps.
Mar 13, 2011 | RCA RP5430 Clock Radio
Daylight savings time changes at wrong date on my brookstone 'smartset' alarm clock. (It changes at the old date, of course - so it is wrong 4 times a year...)
The DST schedule is hardwired into the older clocks and cannot be modified to run on the new schedule. If the clock has a DST switch, you can can turn it OFF and reset the clock only twice a year. On my old "ATOMIC" clock, I've set the DST function OFF, and I use the time zone switch for my adjustments. Sorry, but your only other choice is a new clock.
Bill B
Apr 05, 2010 | Brookstone SmartSet CD Alarm Clock Radio
Have a sky scan atomic clock model 86715. it does not adjust when we have the time change. What can I do to correct the time.
If this model has a DST switch on the back, make sure that it's turned ON. If there's no DST switch you can force a manual change by changing the time zone setting, but you'll need to do that twice a year. Also note that if the clock is more than two years old, turning the DST switch ON will make the clock conform to the old DST changeover dates.
Bill B
Apr 03, 2010 | SkyScan 86709 Atomic Wall Clock
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
My atomic clock jumped an hour ahead. how do i fix it?
DST was set in the wrong setting. Change it and it should correct itself overnight.
Mar 26, 2010 | La Crosse Radio Controlled Atomic Clock
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Mar 10, 2008 | Baby Gear
so long as the US atomic clock adjusts their daylight saving times then you should be fine check this link for some more details (about the scr 110 but seems to be basically the same) http://www.amazon.com/H-H-Scott-SCR110-Atomic-Clock/dp/B00004TZDN/ref=sr_1_2/104-1966292-9407907?ie=UTF8&s=electronics&qid=1173502881&sr=1-2 hope this helps :)
Mar 10, 2007 | H.H. Scott SCR120 Clock Radio
RCA RP5430 Clock Radio Logo
520 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
