Question about NEC MT1075 Multimedia Projector
Our church has two projectors Fron and Rear). Both are sourced from the same HP computer using SongShow Plus. The rear has an excelent picture quality. The front is very poor. The color is almost maxed out but the overall pic quality still looks washed out. The colors do not pop. Even the black backgrounds look grainy and washed out. Could the bulb need replacing or could it be signal loss. The units are feed with coaxial wire. The front projector is twice the distance from the source relative to the back. The front signal wire is probably 200 feet.
  • 37 Answers
You might need a new bulb depending on how many hours its been used, if over 2000, then yes. But 200 feet away from the screen is probably to far, especially if there is light on in the room your in, the further away the projector is makes each pixel beigger resulting to the less quality its going to be, the more light in the room, the less quality, try moving the projector closer to the screen or, by making it darker in the room.
Posted on Jul 12, 2009
    Champion:
  • 205 Answers
Is this a new setup or did the projector recently degrade. I have more questions than answers, but I will make some assumptions based on what i have todate. 200ft for a coaxial run is a long run and should be amp'ed up for proper signal strength on the other end. Front projection, screen is also reflecting all the room lighting as well. Rear projection by design deflects all ambientl light and allows the image to come beaming thru.
The projector referenced is a 4200 lumens that is good, but the resolution is XGA. If your using a single coax, my guess is your coming off a video switcher and that is a composite video signal. You have to things working against you. The video is 480 res at best and thus the projector is scaling to the xga res. That is grainy 101! Then the signal quality, and finally. If the assumption of the video switcher is correct, and your using pc graphics and converting them to video via switcher, you just hammered the high quality graphics and stuffed them down a tooth pic. I can help you solve this, but need more specifics. thanks
Posted on Jul 07, 2009
  • 22 Answers
Using composit cable will not help better to use VGA also what hrs do you hacve on the lamps and have the projectors had their 1000Hrs service?
Marc Engineer
Posted on Jun 17, 2009
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Showing flourescent pink on display
Went to another site that offered commonly asked questions about product. Found the answer at a faster pace.
Jan 21, 2010 | Epson PowerLite S1 Plus Multimedia...
Hp xp 7030 picture is b/w on all inputs. the picture is allso flikering
Any DLP projector that is showing a B&W image, INCLUDING the projector menu, has a shattered color wheel. It can be replaced, provided you can get the part from HP, who will be your only source for parts.
Oct 21, 2009 | HP xp7030 Multimedia Projector
How to get tv working on the projector
It depends, check if your TV has Video Line Out (yellow pin) jack at rear then hook it in external video source/ input of multimedia projector to watch TV picture through projector.
Thanks.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
We have a BENQ PB6100 and the picture is reversed can you help us?
By selecting Source in menu you can go to Mirror and select the posistion you want the image to be IE: front, rear , ceiling, floor
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Projector signal goes bad after 25 minutes
It appears the projector was over heating. Why it affected the DVD signal and not the computer signal, I do not know. The other confusing thing was the projector was hanging off the ceiling and should have had plenty of circulation. When I climbed up to check for excessive dust, I found that the lens cap had been placed over the intake vent. I blew off the dust and removed the cap. After running the projector for an hour, it appears that the problem has been solved.
Sep 22, 2008 | Dell 4100MP Multimedia Projector
Can't get computer images to project
Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
Hp vp 6210
connect the laptop with projector and power up the projector and select the input 'computer' now start the laptop. the Projector will automatically detect the signal. secondly also chek with the display setting set to 800x600 then check with higher resolution.
Mar 28, 2008 | HP VP 6210 Multimedia Projector
I can't connecte my laptop to the projector
To be able to provide you with an appropriate solution, pls post back with additional information on:
1. to what will the 2nd projector be connected to;
2. what is the brand/model of the 1st projector;
3. what is the brand/model of the video source (laptop, DVD, others); and
4. will you also be using the audio in/out.
Looking forward to your next post. Cheers.
Jan 05, 2008 | NEC VT460 Multimedia Projector
NEC MT1075 Multimedia Projector Logo
188 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
