Question about Poulan Pro Chain Saw 46cc 20"
Stripped bolts bolts that tighten the brake / bar turn while trying to tighten the nuts; any suggestions?
  • 4 Answers
Sounds like the bar stud is stripped out in the case. you might have to have a thread insert, like a Heli-coil, put in.
Posted on Mar 11, 2009
I stripped the head of the shaft end bolt of my Frigidaire front load washer. How can i get the bolt out ?
There is a special socket set made for stripped nuts and bolts. Sears sells it. There are about five sockets in the kit, each covers a couple different sized stripped nuts/bolts. The socket is spiraled inside and tightens onto the stripped head as you turn it counterclockwise to remove..... DW
May 12, 2014 | Washing Machines
Loosen stripped bolt
wedge something in-between the nut and what its holding like a flat head screwdriver this will give you leverage to allow the nut to move onto good threds
Mar 30, 2014 | Schwinn Exercise & Fitness
How to change the struts on toyota previa 1994
. Place a set of wheel chocks behind the rear wheels of the Previa. Lift the front of the automobile on the side that you are starting with. Place a jack stand under the Previa and raise it to the frame of the vehicle. Remove the wheel using the lug wrench to loosen the lug nuts.
2Remove the brake caliper by loosening the retaining pins with a socket and ratchet. Secure the caliper out of the way using a wire tie. Do not allow it to hang by the hose. Remove the brake rotor from the wheel. Disconnect the ABS sensor from the strut if the Previa has anti-lock brakes.
Sponsored Links
Bridgestone PromotionGet Either A Reward Card Or Kindle When You Buy 4 Select Ecopia Tires.BridgestoneTire.com/Promo3Remove the nut securing the brake hose bracket to the strut with a wrench. Disconnect the stabilizer bar link using a wrench. Loosen the two lower bolts on the strut assembly with a socket and ratchet but do not remove them. Remove the cotter pin from the tie-rod end using the pliers.
4Remove the castellated nut with a wrench. Separate the tie-rod end from the wheel knuckle. Remove the top three bolts from the strut using a socket and ratchet. Access the bolts from inside the engine compartment on the wheel well. Remove the bottom bolts and take the strut from under the Previa.
5Place the spring compressor on the coil spring and tighten it enough that the pressure is taken off the spring seats. Remove the center nut from the strut shaft using a wrench. Remove the coil spring cap, coil spring and spring seats from the strut. Put the coil spring on the new strut along with the spring seats and cap.
6Install the center nut and tighten it with a wrench. Place the strut on the Previa and loosely install the two bottom bolts. Connect the top three bolts and tighten them with a socket and ratchet. Tighten the bottom bolts with a socket and ratchet. Connect the tie rod to the wheel knuckle. Install the castellated nut and tighten it with a socket and ratchet.
7Insert a new cotter pin in the tie-rod end and spread it open with the pliers. Connect the stabilizing bar link. Tighten the bolt with a wrench. Connect the brake hose bracket to the strut and tighten the nut with a wrench. Connect the ABS sensor if the Previa has antilock brakes.
8Put the brake rotor on the wheel assembly. Cut the wire tie securing the caliper using the pliers. Place the caliper in the mounting cradle and tighten the locking pins with a socket and ratchet. Install the wheel on the Previa. Tighten the lug nuts with a lug wrench. Remove the jack stand from under the Previa. Lower the vehicle to the ground.
Apr 28, 2012 | 1994 Toyota Previa
How to install rear struts on a 1999 llexus
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Print
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    Rear tire and wheel assembly Rear stabilizer link Rear axle shaft nut Rear disc brake caliper and disc Speed sensor Parking brake assembly at the wheel hub No. 1 and 2 upper control arm assembly No. 1 and 2 rear suspension arm assembly Toe control link Rear axle from hub assembly using a plastic hammer No. 2 rear wheel bearing dust deflector using a screwdriver 4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
  1. Install or connect the following:
    Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm) No. 2 rear wheel bearing dust deflector using a screwdriver Rear axle into hub assembly No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt. No. 1 and 2 rear suspension arm assembly. Temporarily tighten. Toe control link. Torque new nut to 52 ft. lbs. (70 Nm). Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm). Parking brake assembly at the wheel hub Rear speed sensor Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer. Rear brake disc and disc brake caliper
  2. Adjust the parking brake.
  3. Stabilize the suspension as follows :
    1. Install the wheel(s).
    2. Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
    3. Raise the vehicle.
    4. Remove the wheel.
    5. Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
  4. Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
  5. Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
  6. Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
    NOTE If it is necessary to replace the hub or bearing, replace the components as an assembly.
    Rear tire and wheel assembly If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way. Brake rotor or drum 4 bolts and pull off the rear axle hub O-ring
To install:
    Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm) Rotor or drum Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm) Wheel
  2. If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
    Negative battery cable Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Cotter pin, lock cap and the nut holding the halfshaft to the rear axle Suspension member brace by removing the 2 bolts Halfshaft bolts and washers Halfshaft from the vehicle Strut rod
  4. Place matchmarks on the adjusting cam and body for the No. 1 control arm.
  5. Remove or disconnect the following:
    Nut and adjusting cam Nut on the axle carrier side of the No. 1 lower control arm Separate the control arm from the axle carrier No. 1 lower control arm Stabilizer bar link from the No. 2 lower control arm.
  6. Place matchmarks on the adjusting cam and body.
  7. Remove or disconnect the following:
    Nut and adjusting cam from the No. 2 lower control arm Nut and bolt holding the No. 2 lower control arm to the axle carrier No. 2 control arm from the vehicle Nut and bolt on the lower side of the strut assembly 2 upper control arm set nuts and bolts Axle carrier with the upper control arm
  8. Secure the axle carrier in a vise.
  9. Remove or disconnect the following:
    Nut holding the upper control arm to the axle carrier and remove the control arm Dust deflector. Use a suitable prytool. Oil seal
    Fig. Removing the oil seal (inner)-LS 430
  10. Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
  11. Remove or disconnect the following:
    Axle hub
    Fig. Removing the axle hub from the axle carrier-LS 430
    Backing plate. Inner race (outside) from the axle hub
    Fig. Removing the inner race (outside) from the axle hub-LS 430
    Oil seal (outer) from the axle
    Fig. Removing the oil seal (outer)-LS 430
    Snapring from inside the axle housing Bearing from the axle housing
To install:
    New bearing to the axle housing Snapring to the axle carrier, using snapring pliers New outer oil seal. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (outer)-LS 430
    Backing plate to the axle housing. Do NOT install the bolts or nuts at this time. Inner race (inside) to the axle housing Axle hub to the axle housing Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm). New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (inner)-LS 430
    New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier. Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm). Axle carrier and upper control arm to the vehicle as an assembly 2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm) Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm). Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm). Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm). Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm) No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm). Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm). Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm). Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm) Parking brake shoes and cable Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm). Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm). Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm). Lock cap and cotter pin Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm). Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm). ABS speed sensor and wiring harness Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm). Rear wheel(s) Negative battery cable
  2. Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
  2. Remove or disconnect the following:
    WARNING Be careful not to damage the boot and ABS sensor
    Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Toe control link Separate upper control arm assembly Shock absorber from axle carrier Suspension arms No 1 and 2 from axle carrier Rear axle from carrier
    Wheel bearing dust deflector 4 bolts and axle & bearing hub assembly
To install:
    4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm) Rear wheel bearing dust deflector Rear drive axle Upper control arm. Temporarily tighten No 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm) Shock absorber. Temporarily tighten Toe control link. Tighten to 37 ft. lbs. (50 Nm) Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm) Height control sensor Parking brake shoes and cable Speed sensor Rear disc brake caliper Fully tighten shock with new nut to 52 ft. lbs. (70 Nm) Rear tire
  2. Inspect and adjust rear wheel alignment
  3. Check ABS speed sensor signal
    Rear wheel Wheel speed sensor Axle halfshaft Brake caliper and rotor Parking brake shoes Parking brake cable No. 1 lower suspension arm bolt No. 2 lower suspension arm bolt Toe control link Upper ball joint Axle carrier from the vehicle
  3. Press the hub out of the wheel bearing, then remove the backing plate.
  4. Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE Use a new toe control link nut for assembly.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Backing plate bolts: 43 ft. lbs. (59 Nm) No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm) No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm) Toe control link nut: 36 ft. lbs. (49 Nm) Upper ball joint nut: 80 ft. lbs. (108 Nm) Brake caliper support bolts: 77 ft. lbs. (104 Nm) Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
    Rear tire and wheel assembly Brake caliper support bracket Brake rotor Skid control sensor wire 4 bolts and rear hub and bearing assembly Skid control sensor
To install:
    NOTE Inspect bearing back lash and hub deviation
    Skid control sensor Rear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm) Skid control sensor wire
    Rear disc Rear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm) Flexible brake hose Rear tire and wheel
  2. inspect and adjust rear wheel alignment
Stabilizer Bar
  1. Remove the rear wheels.
  2. Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
  3. Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
  4. Remove the stabilizer bar.
To install:
  1. Install the stabilizer bar.
  2. Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
  3. Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
  4. Install the rear wheels.
  5. Inspect and adjust rear wheel alignment.
Strut & Coil Spring
    CAUTION Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
    No. 2 luggage compartment trim cover Left and right deck side trim box Rear luggage compartment trim cover Front luggage compartment trim cover Left and right side luggage compartment trim covers Rear wheel Rear wheel fender liner No. 2 differential support protector Rear suspension member brace Rear No. 2 lower control arm Mounting bolts and strut assembly
  3. Secure the strut in a vise.
  4. Compress the coil spring
    Upper strut retaining nut Suspension support Upper insulator Bumper Coil spring Insulator
Dec 26, 2011 | 1999 Lexus ES 300
My neighbor has a 1996 Dodge 1500 4x4 pickup and asked me to help him change the front shocks. The top is a standard stud/nut attachment. The bottom has a bolt head we can see, but the other side of the...
On a lot of models the nut is welded to the arm and does not need to be held. Try turning it and watch the nut. If the bolt comes out it sould go back in the same way. Be careful not to over tighten - if the threads are stripped the nut will have to be replaced.
Jan 16, 2010 | 1998 Dodge Ram 1500 4WD
Chainsaw chain will not tighten on the guide bar
The two nuts on the bolts for the chain bar, need to be loosened.
Then the tension screw is tightened by turning it Clockwise. (To the Right)
If the chain doesn't tighten,
1.Insure that the nuts are loose enough, so that the chain bar may slide.
2.Insure that the tension adjusting screw does not have stripped threads, nor the threaded part of the case it screws through.
Oct 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Sticking rear shimano ultegra brake caliper
That rod (bolt) thru the middle that holds ur brake together gets too tight. You can disassemble and clean it or just loosen the nut on the front and watch em snap back to open position
May 08, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Rear wheel removal & oil filter cap w/stripped bolts
I would tap the nut with a hammer then use vice grips on the filter nut. I would ensure the corect wrench is used on the axle bolt and give it a good tap as well before wrenching it off. Try the folks at
www.hondabikes.net
I use em for my 750 and 650 honda.
Jan 20, 2009 | 1982 Honda GL 1100 Gold Wing
Bicycles Brakes Tightening
Are the brakes center pull or side pull?
Center pull would have a nut directly in the center of the brake. Now go to the brake lever on your handle bars and tighten the turn screw where the cable handle is. Keep turning the nut till your brakes grip.
If you have side pull brakes. Then where the cable meets the breaks. Their is a nut that the cable slides through. Loosen the nut and firmly pull the cable till its tight and retighten the nut.
Nov 03, 2008 | Cycling
Poulan Pro Chain Saw 46cc 20" Logo
174 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
