Question about Acer X221WSD Monitor
Upon turning on my computer monitor turns on for only about a half second then goes blank
  • Anonymous Apr 26, 2009
    moniter stays on for a second or two, then shuts off. Technically I could still use the computer, but I'd have to turn the moniter on every few seconds.
  • DanPapallo
    DanPapallo May 11, 2010
    When it turns on - What appears on the screen? Is it just the manufacturer logo etc or can you see your normal computer desktop until if disappears?
    Also, what is the make and model of your monitor?
Chances are pretty good that your monitor took a dump
if you have another monitor or borrow one plug it in and see if it works.
that just happened to me and i bought another monitor and all the trouble went away
Posted on Mar 09, 2009
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
VP191B VIEWSONIC MONITOR POWER ON AND PICTURE SHOWS FOR HALF A SECOND THEN GOES BLANK, POWER OFF AND POWER ON PICTURE FOR HALF A SECOND AND GOES BLANK
More likely to have problem in either the backlight light inverter board or bad lamps due to poor solder connections, see http://s807.photobucket.com/home/budm/allalbums
You will need test lamp to narrow down the problem.
Feb 05, 2010 | Computers & Internet
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
Dell tv/monitor picture goes blank after 1 second upon power-up
The synchro transistor has died. The only option is to have it repaired. Just had it happen to mine, can't tell you thye cost yet though as I have a loan monitor while dell fix it. Of course they will find more than 1 item i bet. But a tch who works for samsunhg looked at it and told me it would need to have a new sync transistor. Because its dell he wouldnt touch it.
Aug 24, 2009 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Acer X221WSD Monitor Logo
224 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
