Question about Dell Inspiron 6000 Notebook
Orange battery light on, but computer says its running on electrc
And the light beside it is changing from green to orange. What does this mean?
thanks
L.
  • 64 Answers
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Posted on Mar 09, 2009
    Sergeant:
    Champion:
  • 357 Answers
Orange LED means the battery is low and you need to charge it, once you plug in the AC adapter, the LED should change to green and will stay green as long as the charger is plugged in.
I hope this helps.
Good Luck.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Battery light flashing orange, orange, orange, then green over and over. if I unplug the computer it will turn off right away. I changed the battery to one that I had stored away and it's still doing the...
That usually means that you're battery has exceeded it's life expectancy and needs to be replaced. Could also mean that the circuit on your system board that charges your battery is defective and not charging your battery. Remove the battery and use the AC adapter and see if the the laptop turns on with out the Yellow LED flashing.
If so, then you either need a new battery or new system board. If the latter, might be chwaper to buy new computer.
Aug 23, 2013 | Dell Inspiron E1405 Notebook
While my computer is running the light on the frount is flashing orange. I thought it was always green before. Is there a problem
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Oct 05, 2012 | Gateway Computers & Internet
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
What does it mean when the light on the battery is orange?
It should be orange when their is power to xbox, but the xbox is not on. when you turn xbox on the light should change to green if working correct.
Dec 18, 2009 | Microsoft Xbox 360 Console
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Jan 20, 2008 | Computers & Internet
Dell Inspiron 6000 Notebook Logo
1,095 people viewed this question
Alun Cox
