Question about Car Audio & Video
The lights are out of my factory radio
I have a factory GM radio in a 2001 Yukon. a couple of lights were burned out in the past, now none of the lights behind the controls work. The blue florecant screen is fine. just what should show through white. Is this a possable repair I can do or must it be sent in, and if so where could I have this done
  • 94 Answers
Best bet is having a after market radio put in it will be least expensive that way. or just take the radio to the dealer and they should be able to sell you a remanufactured radio i hope this helps you
Posted on Mar 09, 2009
Lost power in engine, engine light on traction on and radio and gauges dont work , battery keeps draining on a 2003 gmc yukon
If there is no power in your car more than likely it has to do with your car battery being dead try and jump it. Good luck!
GM Tech2 GM Diagnostic Scanner With C card
Dec 18, 2012 | 2003 GMC Yukon
04 gmc yukon. Installed aftermarket radio. Installed a interface and no sound from speakers
It can be issue with Faulty radio AMP or the problem is with loose radio speaker wires.
There is a test procedure,you can do.Click the link below to follow the test procedure.
No sound from speakers on 04 gmc yukon
http://repairhelpcenter.blogspot.com/2012/10/no-sound-from-speakers-on-04-gmc-yukon.html
these will help.
Thanks.
Oct 13, 2012 | Cars & Trucks
My 2001 yukon xl dash is reading, "check oil pressure when i crank it up. the oil level is at zero. do you have any idea what it is? before this hapeened the check engine oil level light flashed on...
well so if i understand right you have no oil in the vehicle? or have you checked the oiil dipstick, GM is known to burn oil so if you go alot more than three thousand miles between oil changes than that will cause the oil to burn off and cause the lights to come on, or you might have a leaky filter or drain plug and its loosing oil, so first pull he diptick check level and if you need oil just go get an oil change and they snould let you know of any leaks there may be
Aug 31, 2011 | 2001 GMC Yukon XL
My 2003 Yukon XL Instrument Cluster has stopped working completely. Does GM cover this problem?
{: ) Do you mean cover under warranty or something? I don't think so. They can only help you deal with the problem if you decide to bring for repairs.
Mar 26, 2011 | 2003 GMC Yukon XL
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
I have a 2001 yukon and am wanting to change out the radio. Is the radio going to need any extra parts due to anti theft security?
Depending on what radio you install you will need an installation kit so you can plug in your OEM wiring and not have to splice and decipher factory wiring. Check with Best Buy or Crutchfields' (online)
Jan 06, 2011 | 2003 GMC Yukon XL
RESET THE LOW TIRE PRESSURE LIGHT AND UNLOCK A RADIO?
Take the radio to your GM dealer and go to the service department. They will be able to figure out the unlock code in less then 5 minutes and, at least when I had them do it, didn't charge me a dime.
Good Luck
Oct 08, 2009 | 2001 Chevrolet Impala
None of my interior lights are working ever since
have you check fuses, that s a good place to start. did you take it out and replace it, or not?
Sep 25, 2009 | 1996 GMC Yukon
I was repairing a broken wire for the low beam headlights on the turn signal/dimmer switch in the column, wich i had to do one other time, and somehow enabled the theft security system.(the lights won't...
you have to take it to GM dealer to get that problems fix due to your computer effects security and ignition. did you by chance disconnect the battery for any reason or removed the radio? your computer need to be reset and your key fob don't even reconized its own remote. GM vechicle is known to have common problems with the radio removal and dead battery reset the computer it self. hope that help some..good luck!
Jul 10, 2009 | 2001 GMC Yukon XL
I have a 2005 gmc yukon xl and am not get fire to the amplifier...have new radio and amp...have reset the radio codes but still no sound...how do I get fire to my amp?
Is it all factory equipment? If so you need to go to your local gm dealer and have them program your radios serial number to your vin with a tesh 2 programmer. Sorry but if it is factory stuff that is the only way to get it to work.
Oct 21, 2008 | Car Audio & Video
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
