Question about Sony Computers & Internet
When i log off and the next user logs on the keys on the keyboard are wrong i.e. the j is a 1 the k is a 2 the l is a 3
  • Sony Master
  • 32,281 Answers
The number lock key has been pressed or the BIOS configuration has been configured with the NUM lock on.
Check the BIOS setting.
To release the NUM lock.
Press the number lock key once, if you press it again it will turn the numbers again. It is usually one of the keys above the Function keys (ie F1 to F12 keys).
Posted on Mar 09, 2009
Hard reset dell
Step 1: Restart your laptop and as it restarts, press the 'F8' key on your keyboard. Wait until the 'Advanced Boot Options' menu appears.
Step2: In the 'Advanced Boot Options' menu, press the down arrow key to select 'Repair Your Computer'. Press 'Enter'.
Step 3: Choose a preferred language and click 'Next'.
Step 4: Now log in any Administrator user account. Then click 'OK'.
Note: A user account that doesn't have Administrator privileges' cant restore the laptop to its default settings.
Step 5: Click 'Dell Factory Image Restore'.
Step 6: Click 'Next' in the 'Dell Factory Image Restore' window.
Step 7: Tick mark 'Yes, reformat hard drive and restore system software to factory condition'. Click 'Next'.
Step 8: The laptop will begin to restore at this point. Once the restoration process is completed, click 'Finish'.
Feb 03, 2014 | Dell Vostro 1510 Laptop
Need the bios password on my gateway solo 9500
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
Oct 04, 2011 | Axiom Audio Axiom 40GB for Gateway Solo...
Has hdd password that i cant reminber any way to remove it
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Sep 24, 2011 | Computers & Internet
How do you find the log of 9.01 using TI 30xA calculator?
To calculate the common (base 10) log of 9.01, press 9 . 0 1 LOG =
To calculate the natural (base 3) log of 9.01, press 9 . 0 1 LN =
Both the LOG and LN keys are on the top row of the keyboard.
May 09, 2011 | Texas Instruments TI-30XA Calculator
When i press a key with a letter and a number the n4mber appear. i have to press fn for the letterns to work
press Fn+ numlock key for some laptop its F8. that will disable the number lock. thanks
Mar 28, 2010 | Lenovo ThinkPad T61 Notebook
I was using my laptop and now for some reason I can't type on the keyboard or log off. Did I hit a key and lock it? How do I unlock it?
Use the touchpad and right click on the Taskbar then click on the Task Manager to open it. In the Task manager, click on the users tab to view the list of the logged on users then click on the username that you want to log off then click on the Log off button.
After logging off again use the touchpad to restart the Computer by selecting the appropriate option.
As the Computer is restarting press the button that says on the screen to press to enter to SETUP screen. This will make the Computer boot to the BIOS. In the BIOS check if the keyboard is working by pressing the arrow keys to select the Exit menu to select the restore to default option.
If the keyboard is not working in the BIOS then the keyboard is failed and service is required.
Nov 03, 2009 | HP 550 Notebook
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
HKEY_USERS\.DEFAULT\Control Panel\Keyboard
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
Win xp log on failed
to avoid this problem you run in safe mode option to your system.to run in safe mode follow the step...
restart the system and then press on start F8 key from keyboard then choose safe mode option...
your windows has corrupted.
so you can also restore the system in previous date.....further detail on live chat
Apr 14, 2009 | Microsoft Windows XP Home Edition
Vista log in
The user profile seems to have corrupted. The account that you log into is corrupt now may be due to incompatencies or incompatibility or may be a virus or a spyware. Alternatively, you can try logging to safe mode window. As you start the computer keep tapping the F8 key on your keyboard at the sametime. You would reach a screen to choose from different boot options. Select safe mode(you would have to use the arrow keys in your keyboard). Log in with the usual username and password. If it logs in, you might see a black window with large icons. Don't worry. Go go start, control panel, user accounts, and create a new account. So you can use the new account. Restart the computer and login to the new user account. You should be good. Make sure the account you create should be an administrator. Later if you want you can delete the user account that you have been using before. You can delete it from safe mode again by going to control panel, user accounts.
May 26, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
