FixYa.com
Tags:
Ricoh IS450DE Flatbed Scanner
Twain driver not WIA on XP
By Duke - usenet poster
We recently upgraded a PC used for high speed scanning from 98 to XP.
Also included in the upgrade was Paper Port 9.0. When using the application
to scan with a Ricoh IS450DE B&W scanner, we are unable to use the Twain 270
driver. There is a WIA driver installed. The Scanner is connected with a
SCSI card.
On another PC with a new model scanner installed and XP , the Scanner does
not show in My Computer on the broken one, it does.
My question after all of that is, how do I get rid of the driver that
windows installed, or at least disable the auto install of the scanner?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
jessie25
jessie25 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If you don't want the driver installed, either do not turn on the equipment
that you don't want installed, or disable plug and play detection.
Windows XP Problem and Troubleshooting Resources
<a href="#"></a>
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
bwwhahahhayou so useful
H
Solution #3
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
The scanner is compatible, it's just that XP auto installs it with the WIA
driver. It works fine using the WIA Driver, but the twain driver will not
coexist. They share the same DLL. I just cannot figure out where to get rid
of the driver and then not allow the auto install which reinstalls it every
time I startup.
Solution #4
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
bluh bluh
Why are you asking that question? Did you bother to check that your SCSI
scanner was compatible with XP?
<a href="#"></a>
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Scanners
driver for umax scanner 4500
i can't find driver for umax... Answer This...
Scanners
help
do you have scanner codes Answer This...
reduced printouts using the...
when I scan using the flatbed... Answer This...
Scanner on a hp750 psc
my hp 750psc has started to... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
