Question about Garmin GPS
USB plug on NUVI200
It seems that the USB plug on my NUVI200 is loose and it will not charge. Is there a way to fix it? Can the unit be opened?
  • 1,606 Answers
Try another usb cable first. All are not created equal and sometimes it will fit tighter. If the usb jack is actually loose then you could replace it by soldering in a new one. It's not a big job but you might have trouble finding someone to do it. Your other option is to call Garmin and see what they would charge to fix the unit. Usually its a fixed price and they will swap yours for a new one. Might be the easiest way .
Posted on Mar 09, 2009
    Problem Solver:
  • 10 Answers
These guys are really good at fixing a loose USB. Check them out. Good luck.
www.nabilselectronics.com
Posted on Oct 04, 2013
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
- Jim
Oct 19, 2009 | Garmin GPS
USB connector in the back is loose and will not
If the connector in the back is loose, its not a Nuvi 350. A nuvi 350 has the connector on the side. In any event, please see this link:
- Jim
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Recharging issues..
check to see if you can charge it via another unit like a pc or a usb wall charger, if it does than your ports are getting loose from use or going bad call Sony if thats the case, its 18003457669. good luck!
Aug 12, 2008 | Sony Playstation 3 (PS3) Console
Help!
Turn on your garmin out of the car, connect to a PC via USB cable and see if the battery indicator goes away. If it does then the USB to PC cable is working and charging the unit. To test the car adapter, you can unscrew the tip of the plug to examine the fuse. Most Garmin car charger units have a light on them that ilimunates when you plug it in and turn the ignition. It could be that the plug is just loose in the socket. The picture shows the unit running on battery. If you plug in the usb cable and this indicator goes away, then it should be charging.
Jul 25, 2008 | Garmin StreetPilot c550 GPS Receiver
I have a navman f20 that has suddenly stopped working ...it just wont switch on?? it was working perfectly yesterday then today when i went to use it it just wont turn on if i plug it in to charge instead...
I had the same problem, turns out that it was a flat battery, which was caused by the usb socket on the gps. The socket was loose and not allowing the battery to be charged.
The usb socket on mine is now not attached as it came completely loose. You may have to get a Tech to resolder it for you.
Jul 22, 2008 | GPS
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
GPS Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
