Question about Refrigerators
I hear a fluttering noise from the refrigerator after I use the icemaker or water dispenser (GSS25WGTI BB)
  • KP44 Mar 09, 2009
    So this noise is a normal occurence? It's pretty loud!!
  • KP44 Mar 14, 2009
    Thanks
  • 400 Answers
That would come from water being replenished in the icemaker or dispenser.
Posted on Mar 09, 2009
  • Shane Seaman Mar 10, 2009
    Yes, it would be pretty normal, the amount of noise is different from fridge to fridge depending on how the tubing is routed.
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Jul 14, 2008 | LG LSC26905TT Side by Side Refrigerator
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Jan 21, 2010 | GE GSH25JFR Side by Side Refrigerator
ICEMAKER /WATER
The line in the back of the freezer section is froze up. Remove the ice-maker and use a heat gun or hair dryer to thaw. be careful not to put the heat gun or dryer to close. It wont take long to thaw. BB
Dec 15, 2009 | GE Refrigerators
Water dispensing by itself without anyone touching the dispenser!
Reverse the wires you took off the solenoid, I think you have the icemaker wires on the water disp side and the water disp on the icemaker
Feb 28, 2009 | Frigidaire Refrigerators
Its probably way too late, but ours was delivered / came with the water pipe being crushed at the front right at the bottom of the fridge/freezer. So I would check the full length of this small diameter pipe.
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
