Question about Cobra Radio Communications
Cobra 148nw st sound tracker - Need to test this yard sale find
There are three prongs to hook up, two on left one on right, I'm thinkin two 12v and one ground. But it looks to nice to short it up.
  • Gregm43 Mar 09, 2009
    This is a Car CB
    Problem Solver:
  • 6 Answers
Go to any cb shop maybe even radio shack in your area. these plug in cords are fairly easy to find. even check with other cbers around you they may help you. these cords are usually fused so you shouldn't mess up. red fused to voltage and black to good ground. good luck
Posted on Mar 09, 2009
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
I don't know how I copied and pasted so much sorry about that. But my question is I have orange and red wires with fuses and black wire without do I hook both red and orange to hot and black to ground?
it depends on what radio if you have a cobra 18wx style or maxon's, or a radioshack type the red is constant power 12v, orange is a switched 12v.. IE key like a stereo, and black is ground. if you have a 25 or 29 ltd types or exports they only have 2 wires red 12v and black ground. but you do find some power cords that have all three, and the orange on the 25 / exports are not used.
Feb 09, 2011 | Cobra 25 WX-NW-ST 40-Channels Base CB...
No problem just need wire diagram for 4 pron mike on cobra 29 night watch sound tracker
go to cobra web site click on contact us tell them what you need and thay mite be able to send it to you
Jan 03, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
Need to wire a high gear m75 for acobra sound tracker
It should already be wired for that radio. Its a cobra mic, on a cobra radio, its all wired for cobra. Witch is a very common mic wiring.
Nov 09, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I picked up this monitor at a yard sale it says dc input?? is this the power supply? how do i hook up a ac cord?
If it says DC input and there are no other socket which has three prongs(this is for the AC input), all you need is an adapter, which you will plug to a wall socket and the other end would be plugged to the flat panel, it works like a transformer, just like any power supply, like for laptops, just try to find the correct voltage, 12v,16v or whatever is needed by the panel. Often you can find the voltage require on the panel itself, reading as POWER INPUT, xx volts or Power requirement.
Thank you for using Fixya.com
Oct 27, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
We have a Cobra 148 nw st Sound Tracker When
It could be..
Final blown : worst case
bad mic : try another one
CB/PA switch on PA instead of CB
CB/WX swithc on WX instead of CB :you cannot transmit on weather.
Broken wire on mic jack.
Try the mic and switches first, and if that doesn't help you may need to take to tech. You can find one at a cb shop usually at truck stops.
Oct 27, 2009 | Radio Communications
Yard sale find
red should be 12v black should be ground test is on a car battery.
Mar 09, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
148NW ST No TX AM or SSB
finals need to be replaced, as they are fried,, hence no output,,and if you are lucky you haven't fried the pre-amp as yet....as the pre amp is REAL EXPENSIVE....so stop keying it up
Jul 27, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
65 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
