Question about Nokia 3230 Cellular Phone
The LCD of my nokia3230 wont work
My unit fell to ground from a height of almost 1 meter. it slip from my hand and it is in level of my chest. when i picked it up, the nokia opening theme that should be at the bottom was moved upward and the backlight did not show up. what i did, i took off the battery then try to place it again. when i tried to "on" it, the keypad lights work, i can hear the nokia opening tune, but the LCD just wont work. what could be the problem? help!
  • 450 Answers
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
Posted on May 13, 2010
Can the headlights be adjusted in 2013 Camry
Yes they should be adjustable because people change tyre profiles front to rear and this alters the drive angle.The adjustment screws are in the headlamp housing behind lamps accessed from the hood/ bonnet side.you do need to do this properly so they align together at the legal height for full beam.there is plenty of online information on the correct height for full beam...once you have made sure all Your tyres are at the right pressure....park on level ground ...at least 3 meters from front of a wall ....and at right angles to the wall....measure the height to the centre of headlight to ground .......mark the right light horizontal line for correct height on the wall and make sure you put lights on full beam....they should shine slightly below (say an inch )to the marked the measurement of height of lamp on the vehicle....adjust until the right hand light horizon is an inch below...now mark vertical line to cross centre of reflected light....this will give you a register point to mark where the left light should fall ...this will be exact distance apart as on vehicle and again adjust left until it falls below 1inch of the measured height line of lamp on car......mark distance from right to left light and mark the same height in chalk....then adjust left light to pinpoint marked chalk cross.adjust the beams by turning the spring loaded screws behind the lights.once you are happy check dipped positions....on right hand drive the lights should dip below and left.left hand drive dip below and right.you probably didn't need so much info but ...hey it's free and it saves any misunderstanding.hope this is of help...please vote.thankyou.
Feb 07, 2015 | Cars & Trucks
Can't find the relay for the electronic level control(elc) for a 1999 cadillac eldorado
1. Locate the automatic level control height sensor under the rear of the vehicle on the rear suspension support. If the back of the car is too low and will not pump up, ground pin B Yellow wire and see if the compressor will come on and the car will raise.
2. If the car does raise when pin B is grounded, check the powers and grounds to the height sensor.
3. If the powers and grounds are OK and the pump does come on and the car raises when pin B is grounded, the height sensor will need to be replaced.
4. If the car is too high and will not come down, ground pin E White wire at the height sensor to see if the car will lower.
5. If the car lowers when the White wire in pin E is grounded, check the powers and grounds to the height sensor.
6. If powers and grounds are OK and the car does lower when pin E is grounded, the height sensor will need to be replaced. Tech Tips: There are two different automatic level control systems for this car; one is without RPO F45 and one is with RPO F45. The system without F45 has an automatic level control height sensor and with F45 the automatic level control compressor is controlled by the continuously variable road sensing suspension module. Tests/Procedures: 1. Using a head lamp as a load, test the ELC height sensor power/grounds.
2. The power feeds are: Orange wire, pin C and a Brown wire, pin D.
3. The ground is pin A, Black wire.
4. Ground the White wire at the height sensor, check that the vent solenoid in the ELC compressor clicks and vents the air from the system. Author: Bill Siegmann
Dec 24, 2012 | 1999 Cadillac Eldorado
Gas hand doesnt work
The most common cause of the fuel level meter not working is that the fuel level meter sending unit located inside the gas tank is defective.
Nov 01, 2012 | Buick Cars & Trucks
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
How to calculate the weihgt of circular cones
(1/3) x pi x radius2 x height x density = pounds
where ::
radius = radius of base in inches
density = pounds per cubic inch
height = height in inches
(or you could use feet, meters, cm, mm for radius & height and use kg for density or wahtever units you wish as long as the units are consistent)
Charlie
Feb 22, 2011 | American Standard Plumbing
I don't have the cup that goes with my Hitachi rice cooker. Using a regular cup, how much water for each cup of rice?
I suggest that after you wash the rice on your rice cooker bowl level it and measure the height of your rice using your hand finger ( middle finger ) then that is also the water you need. but put the water slowly to maintain the level of the rice because this is also you guide to level it. I mean. 1. wash your rice. 2. level it ( the rice ) inside the bowl of rice cooker and measure the height of your rice by using your hand finger ( the middle finger ) and remember it. 3.put the water slowly, and your hand finger should be from the top of your rice to measure the height of your water. I hope you understand me!\ just try it because this is the way that how to cook the rice even any kind of bowl.
Feb 16, 2011 | Hitachi RD4056P 5.6-Cup Rice Cooker
How do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
After a drop from 1 meter height, hour hand stopped in between 11 and 12 hours...reset the watch, adjusted hands thorougly, but it stops when reachs same position...help me please!!!
could be following Issue
1, Hands out of alignment & blocking each other
2, Marker on dial fell & stoping watch hands motion
3, Gear train setting disturb or Gear tooth break
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 06, 2009 | Watches
Antenna mounting
according to FCC rules RULE 8 - Antenna Height
{A} "Antenna" means the radiating system (for transmitting, receiving or both) and the structure holding it up (tower, pole or mast). It also means everything else attached to the radiating system and the structure.
{B} If your antenna is mounted on a hand-held portable unit, none of the following limitations apply;
{C} If your antenna is installed at a fixed location (whether receiving, transmitting or both) it must comply with EITHER one of the following:
[1] The highest point must not be more than 20 feet (6.10 meters) higher than the highest point of the building or tree on which it is mounted;
or
[2] The highest point must not be more than 60 feet (18.3 meters) above the ground.
{D} If your CB station is located near an airport, and if your antenna structure is more than 20 feet (6.10 meters) high, you may have to obey additional restrictions. The highest point of your antenna must not exceed 39.37 inches (1 meter) above the airport elevation for every 109.36 yards (100 meters, 1 hectometer) of distance from the nearest point of the nearest airport runway. Differences in ground elevation between your antenna and the airport runway may complicate this formula. If your CB station is near an airport, you may contact the nearest FCC field office for a worksheet to help you figure the maximum allowable height for your antenna.
Jul 20, 2009 | Cobra MRF55 2-Way Radio
Nokia 3230 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
