Question about Samsung DLP HL-P5663W 56" TV
Samsung 46 DLP picture freezes and then....
Lines go through the frozen picture. I can still hear whatever I am watching but the screen eventually goes black. The TV is about two years old, but based on how much we actually use it its probably closer to 1 years old. I figured I check online to see if anyone has any solutions before I start looking for a new TV. Any suggestions?
Thank you in advance!
  • 39 Answers
Common problem on samsung. bad DMD BOARD. these are modules located on light-engine. there very proud of this little jewel. usually parts cost 400-500.00 dollars for the shop. after mark-up & labor don't be shocked at 600.00-700.00 repair bill. this is of coarse for dmd replacement. 85-90%. if logic board, est. 400-500.00 repair. mch
Posted on Mar 09, 2009
Samsung 46'' dlp
This is most likely your Digital Processor Module. So far most all makes are selling them as a complete Light Engine Assembly which includes the light tunnel, digital module and color wheel. They are rather expensive, some are in the $800.00 range, a few more dollars and you have a new set.
May 17, 2009 | Samsung HL-P4667W 46" Rear Projection HDTV
Scrambled picture with DVD or Video Game
You have a bad digital board. Expect to spend some serious money to repair this.
michtech
Feb 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung 50' DLP Tv. Is it a lamp?
there is a lamp door in the back for end users open it up and check it out, could be the color wheel exploded also
Jul 08, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Apr 03, 2008 | Samsung DLP HL-P5663W 56" TV
TV Picture Freezes and Turns Off; Cannot Use Remote
My shop had this problem yesterday. We had to change the DMD to correct it. One of the data lines was being drawn down intermitently. This doesn't eliminate the digital PCB, but, we have seen the DMD do this more than a digital. You should have an authorized shop do the repair. Contact Samsung at 1-800-SAMSUNG or contact by email: http://samsung.com/ContactUs/ContactUs.htm Hope this helps.
Mar 30, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
598 people viewed this question
Henry  Thomas
Henry Thomas
