Question about Sharp R-1510 Microwave Oven
Sharp R-1510 Start Button Not Working
First the ''opener'' button started sticking a little bit when pressed, now the start button no longer works.
Any advice on where to start?
  • eli2009 Apr 02, 2009
    We have the same problem..if we hold the start button just a little bit the unit will function, but if not held in it won't heat.  The timer works but, the microwave portion does not.
  • David Kolb Nov 26, 2011
    How did you remove the control panel to replace the button as I have the same issue
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Posted on Jun 14, 2010
  • rocketenterp Jun 17, 2010
    Update: Ok, so the bird feather wasn't that strong ;-) It broke.
    Replaced it with a toothpick. The toothpick was too fat, so I cut off the pointy end and sanded a 3/8" piece with an emory board. Cut off the rest and sanded the ends flat. Much better fit and seemingly longer lasting; we'll see. Still beats the hell out of replacing the whole door.
    Basically anything that will fit, will probably work, and I'd really like to find a nice strong piece of plastic, like the one that was there originally, but so far that has eluded me.
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
The Start button will not stay activated after I hit "start" and will work only if I continually hold the button inward while the time elapses. ? Model R-1510 Sharp Microwave
There have been some changes to some control panel parts, such as the select buttons. It's covered in a page one bulletin here.
The service manual is here. You should also refer to the base model manual here.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you need further help, or need your keypad replaced, etc., feel free to contact me directly here.
Sep 16, 2011 | Sharp R-1510 Microwave Oven
Start button does not work
If this is a Sharp R1500-series microwave (you didn't mention the model number but posted under that) then the most likely problems are:
- broken Start button see here
- bad door switch see here
- bad keypad or other problem see here
Mar 06, 2011 | Sharp R-1510 Microwave Oven
Pressed the "start" button and heard a pop behind
We'd be happy to help you with free assistance - including part numbers, part sources, and service info - if you'll post a new help request to FixYa including the following:
  • brand
  • full model number
  • detailed symptoms
Jan 22, 2011 | Sharp R-1510 Microwave Oven
Microwave will not start
your safety door relay is way out of adjustment
Oct 01, 2009 | Sharp R-403HW Microwave Oven
Microwave start button is not working when I press it.
try to spray the terminal of your keypad still not working replace your keypad.
Sep 09, 2009 | Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
Sharp carousel under counter microwave start doesn't always work
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 14, 2007 | Sharp R-9H66 Microwave Oven
Sharp R-1510 Microwave Oven Logo
678 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
