Question about Ryobi Saws
My Ryobi 10 inch miter saw, model TS 1340 has been working fine for years, now in the last 7 days, I see heavy sparking at the carbon brushes and a drop in power from the saw, there is a strong smell of ionized air and carbon. I replaced the carbon brushes and still I have the same problem, what is wrong and what shall i do? .... I am no expert but I am 'average' with making repairs, I am up for this task! I have photo and video of the arcing at the brushes if needed by any one. 3-08-09
  • david Trompower Mar 09, 2009
    Thanks these are good suggestions. I looked and the copper plates are black in color. The old brushes have discoloration due to the arcing, I am assuming.
    I had to order the new brushes from out of state, as there is no local repair store near me by any means.
    You suggest the possibility of Using a stone to clean the commutator? a great idea, i don't have a special dedicated one but, have a very fine, round, polishing stone I could use
    I will send a picture soon, I also have a movie of the arcing I could send you, however it will not fit here, due to the size limitations of images, FixYa has in place. Are there any other means that i could send you the movie?
    3-09-09
  • david Trompower Mar 10, 2009
    Rowdy45176
    below is a picture of the brushes arcing.
  • 2,176 Answers
It sounds like the armature has developed an open commutator bar. What did the brushes look like that you took out. But before I assume the worst I would unplug the tool and remove both brushes and with a flas light look into the brush tube while slowly rotating the armature looking for a discoloration or raised bar. If not you might bet by with cleaning the commutator with a special stone for this, you might be able to get one at the repair shop where you bought the brushes. If you want to send me the photo of the arcing it might help on my end. Let me know
Posted on Mar 09, 2009
  • David Ford
    David Ford Mar 10, 2009
    Dont need the movie, anything that you can do to clean that commutator would probably help, you could have had a brush stick and arc which discolors the commutator not allowing the new ones to seat properly and that is the fire and arc that you see. It is worth a try first. can you remove the back cover to get access to the commutator with your polishing stone? I in the past have used a WOODEN emory board. DO not put any metal around that area or you will get shocked. Let me know
How do I get the guard out of the way to unscrew the blade. My Ryobi saw is model EMS2025SCL blue color
Try this. Paste the link into your browser.
http://homeguides.sfgate.com/replace-blade-ryobi-10-inch-power-miter-saw-model-ts254-75950.html
Jul 31, 2017 | Ryobi Saws
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
Ryobi miter saw laser is way off. I can get it parallel, but it's about 1 inch away from the actual cut line. How can I fix the laser side-to-side?
Forget it. The lazer site gets obscured and useless after 5 minutes of cutting. It is the most useless improvement I've seen on a power tool in 40 years.
Feb 22, 2015 | Ryobi 10 In Miter Saw With Laser
I just bought a brand new Ryobi saw from a neighbor but he couldn't find the manual. TS1141L 7 1/4" miter saw how do i get one?
Try this site. http://powertool.manualsonline.com/manuals/mfg/ryobi/ts1341.html I could not find your exact model. If this is not close to what you have then there are many other models to chose from. Just click on "ryobi saw" above the manual to see the rest of the models. You should find something very similiar. Thanks and please rate.
Sep 05, 2011 | Ryobi 10 In Miter Saw With Laser
Rec'd a RYOBI 10" miter
I would remove the one already installed and take it to different dealers or large electrical suppliers to match it
Oct 02, 2017 | Ryobi Garden
How do you change the brushes
You have two, 1/2 inch flat head screw things on the right side of the motor, pull them out, the carbon should be at least 1/4 inch long, min, brushes can be bought at the hardware store. The electric brakes on those saws eat them brushes up. Check it out.
Jul 12, 2010 | Dewalt DW712 Factory Reconditioned Heavy...
Saws Logo
1,097 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
