Question about Pioneer Audio Players & Recorders
No sound from speakers?
My sx-850 pioneer receiver has sound from my headphones but none from my speakers?
  • canoso94 Mar 09, 2009
    Is replacing the output relay something a handyperson can replace or would this have to be done by a tech?
    Would the corroded contacts be visible and easy to id in order to replace?
  • 4,234 Answers
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Dan
Posted on Mar 09, 2009
  • ABRsvcs Mar 09, 2009
    The relay is a somewhat sealed unit and an examination will not reveal anything. To confirm the relay as the likely problem, when the unit cuts out, try turning up the volume a little. If that restores the sound, it is likely that the relay is the problem. Also, a bad relay will likely be a problem more if the volume level is lower.
    Dan
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
I have a pioneer VSX 920 receiver that thinks i have headphones pluged in. I have no sound from the speakers and when trying to go in speaker related settings it displays: PHONESIN on the receiver. If I...
I think I just fixed a unit with the same problem. I opened the cover and found where the wire from the headphone jack plugs into a board just beside the power supply transformer. When removed, the unit appeared to select speakers as the output. Since the headphones are never used by the owner, I simply left the headphone cable unplugged. Unfortunately, I didn't have speakers to test it with but the unit appeared to be working correctly.
Sep 07, 2011 | Pioneer SX-315
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
Direct TV remote codes for SX-315
hello i have a pioneer sx-315 it plays great but the sub performs badly.they sound is very low.they really need to perform better.if anybody know any sub that work better please let me know.
Nov 20, 2008 | Pioneer SX-315
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
342 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
