Question about Microsoft Metrologic MS9520 Voyager Barcode Scanner
Scanner beeps. Laser is a dot instead of a line.
Once I plug it into the tower. The scanner turns on and beeps once but there is a dot not a line.
There is also a raspberry tone after awhile coming from the scanner.
There is a problem with the scan engine. The dot is created when the mirror inside the scan engine stops oscillating. If your scanner is still under warranty send it back for repair or request a replacement.
Posted on Mar 20, 2009
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
My eclipse MS5145 is locked after the first scan , what can i do ?
connect the 2nd end of the scanner cable to a ps2 keyboard and reboot
May 11, 2012 | Metrologic Instruments Eclipse MS 5145...
Symbol ls2000 hand scanner won't read barcodes. The laser lights up and it beeps when I scan but it takes in no data. I have tried the sets all defaults programming barcodes but all it does us make a...
If the scanner beeps just once after a scan, than he recognize the barcode and sends the data to the computer. If you dont receive any data, you are waiting for them on wrong interface. Data from USB or KeyboardWedge do come to Notepad/Word etc. The data from Serial RS232 Connection can you see only in Hyperterminal or similar application.
Sep 26, 2010 | Symbol LS2000 (ls-2000-i000ag) Handheld
Detecting scanner
Once you connect the printer to the computer it should get detected by the computer.
You will need to provide the driver Disk only if it asks for the same.
you can download the drivers for the device by going to support(dot)hp(dot)com. Enter the product number or the model number of your hp device and download the driver for the relevant Operating system.
If you need any further assistance please feel free to reply with comments.
Thank you for choosing Fixya.
Note: Kindly replace the dot with "." in the site address
Feb 24, 2010 | HP ScanJet 3200C Flatbed Scanner
Symbol LS9203 barcode scanner won't connect to PC with USB cable
Hi Mluckham. Far more concerning is your "non-moving dot". The LS9203 is an omnidirectional scanner (as you know) and it should emit a lovely grid of lines regardless. If the single dot you're describing looks like that of a laser pointer, then there is a fairly serious problem within the unit and would explain it not connecting. If that is the case, I would suggest looking into your warranty and getting it fixed or a replacement.
Dec 31, 2009 | Computers & Internet
When I plug my brand new scanner into my computer it beeps and I can see some kind of red light turn on but there is no red laser line and my computer does not prompt me that it is finding new hardware?
hi
please resart your computer/laptop
once you restart please install the software for the scanner ;i believe you must have got the installation CD
once it is done plug your scanner to any USB port when promted or after the installtion
I hope this helped
VJ
Mar 15, 2009 | HP Computers & Internet
Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Line down page on copies
what kind of line. Is it solid and think with well defined edges or is it a small thin and dotted? If it is solid with strait crisp edges you will need a new scanner. If it is just a small somewhat dotted you might just have a little something on the scanner glass. Clean it with regular rubbing alcohol and a cotton cloth like an old t-shirt. Don't use swabs or tissue because they can leave lint behind and just give you more lines.
Feb 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Microsoft Metrologic MS9520 Voyager Barcode Scanner Logo
508 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
