Question about Kenmore Washing Machines
Kenmore washer not draining completely
I think I have something in one of the internal drain hoses but don't know how to get at it. The hose outside the washer is clear - I've removed it and it's fine. Is there a way to get to the other hoses inside the machine?
  • Sherri Jackson
    Sherri Jackson Mar 09, 2009
    Well, I removed all hoses and also the pump. Nothing is stuck and the hoses are clear. There seems to be some water trapped in the bottom of the drum - from underneath you can see all sorts of brown "stuff" and there's a really bad smell. To clarify - water drains during the cycles, but the clothes are left soaking wet. And now there's a horrid smell because this water is trapped in the bottom of the drum. Now what?
    Problem Solver:
  • 6 Answers
Your pump has a blockage
Posted on Mar 09, 2009
My kenmore washer molel 110-82873120 is leeking from the top.
Dear R.A.,
If your washer is leaking you should first check the hoses.
  • There are several types of hoses found on a washing machine and the most common are the drain and fill hoses.
  • The fill hoses connect the household supply to the water inlet valve and are normally located at the rear of the washer. Check to make sure that the threaded fittings are tightened securely and that the leak is not caused by the faucet.
  • The drain hose is also located at the rear of the machine and may not be properly installed into the household drain. Verify that the leak is not caused by a restricted household drain that is backing up through the stand pipe.
  • Washers will also have internal hoses that connect the inlet valve to the tub. A defect in this hose would create a leak during the fill cycle.
  • Access the tub inlet by lifting the main top or removing the cabinet and inspect the hoses for signs of abrasion or cracking.
  • Also inspect the other components of the water inlet system such as a siphon break or tub injection assembly for signs of a leak. Check for loose or corroded clamps, and cracked or perforated hoses.
  • Your inlet Valves may also be totally defective and cause the washer to overfill therefore causing a leak over the top.
  • Check for the tub Pressure switch assembly may be defective causing such leak.
  • Your model requires removing the complete cabinet.(front and sides come out as on piece) Here a link to all your machine parts
I think we cover all the possibilities.
Best of Luck,
JP
KENMORE AUTOMATIC WASHER Parts Model 11082873120 Sears PartsDirect
Jul 03, 2015 | Kenmore Washing Machines
Kenmore he5t washer Changed the pressure switch.
F21 means long drain. Yes, there is something be in the hose. You need to open the filter and clean the pump, too.
Oct 19, 2013 | Kenmore Elite HE5t Washer
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
Water won't drain from the tub, think the hose may be clogged. Is there any way to clean the hose without completely dismantling the machine? It does spin but the water won't completely drain out. We...
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Frigidaire FWS833A Top Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
May 08, 2009 | LG WM0001HTMA Front Load Washer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Kenmore Front loader clogged up
open the back panel to access the hoses. look for the largest-diameter round hose and disconnect it. this should be the drain hose. it also should lead to a vertical-rising pipe or hose that then dumps downward (U-tube at top) into your house piping outside the washer. My hunch is the clog is somewhere before the area where you disconnected and may need to remove all hoses from the pump and also clean pump's impeller.
May 30, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
