Question about Panasonic TH-37PX25U/P 37 in. HDTV Plasma
Panasonic TH-37PX25 has no picture
TV has no picture (black) but power light flashes 11 times...Can anyone help with this problem?
  • 32 Answers
SOURCE: Panasonic Plasma TH-42PZ77U Power Light Flashing 7x
The power supply board seems to have died. If its under warranty, check with Panasonic. If not, whats your nearest electronics repair shop? Just make sure they dont charge you an arm and a leg.
Posted on Dec 31, 2007
  • 47 Answers
SOURCE: panasonic th-42pz77u 42ed
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
Posted on Apr 06, 2008
  • 53 Answers
SOURCE: (panasonic TH-42PZ77U plasma) the tv will power on
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
hope this helps!
Posted on Mar 21, 2009
  • 69 Answers
SOURCE: Panasonic plasma tv no picture, turn on clicks
those flashes are codes..send to get fixed
Posted on Sep 20, 2009
SOURCE: panasonic th-42pz700u flashing red light 10 TIMES
pansonic th-42pz700u,red light blinks 10 times set wont turn on
Posted on Dec 04, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
May 8, 2014 - Uploaded by
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Panasonic Plasma standby button flashes 11 times
11 blinks Fan SOS PB Board. 11 blinks of standby light to Panasonic Plasma indicates a fan trouble. Check it. If you want to know more, check this link.
Jan 12, 2013 | Panasonic VIERA TH-42PR10 42 in. Plasma TV
TH-50PX600U Panasonic Plasma TV power light flashes 10 times
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS. You must ahve through knowledge in electronics to detect the exact faulty board and to repair this set. If you are not sound enough in electronics, get this set repaired either by the authorised service center for Panasonic, or by any well experienced service technician.
Just try this link, and select the site named Electro-help. All proceedings to repair this fault is explained in detail there.
Jul 06, 2012 | Panasonic Televison & Video
My tv automatically shuts off then power button flashes 11 times. Can't get tv turned back on
11 blinks Fan SOS PB Board. Either the cooling fan or its control board is faulty. You have to check and locate which one has the fault. Check this link and select the site mamed 'Electro-help' for more details.
Jul 04, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Nov 02, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic TH-37PX25U/P 37 in. HDTV Plasma Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
