When using some of the programs such as MS-EXCEL, the mouse pointer behaves as it has a mind of it's own. It starts jumping up and down and behaves erratically not allowing the control using touchpad. I have Compaq HP presario running Vista. Can some one help please???
  • 335 Answers
First, try cleaning the touchpad WELL with a cloth damp with windex. If still no good, you should try to remove the keyboard, disconnect and reconnect the touchpad cable that goes to the mainboard.
hope this helps
Posted on Aug 09, 2009
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
Short cut key of MS OFFICE and MS EXCEL Plz provide me short cut key
try doing this:
click on start then go to all programs.. highlight the program you wish to have a shortcut to your desktop.. right click your mouse then select send to desktop shortcut
Feb 22, 2011 | Microsoft Computers & Internet
Pointer has a mind of its own and wanders. Sometimes jumps around before it finds my target.
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Dec 11, 2010 | Logitech MX310 Mouse
Jumping cursor. while i type, it skips around, usually to the left, and at the top of the page area.
Are you using an external mouse, Please try to change your mouse, I have experience the same thing before, it seems my mouse does it. If your not using external mouse but rather your laptops mouse pad, Please try to do further testing by touching the pad in different portion and check if the pointer behaves abnormally.
Jul 29, 2010 | Compaq Computers & Internet
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
HOW TO CHANGE THE COLOR OF CURSOR IN EXCEL?
Start, settings, control panel, Mouse, Pointers (tab),
scheme: none
you can use the arrow key to cycle down through the pointers
so you can see them all -- what to avoid. Dinosaur, large/small/colors
Apr 07, 2009 | Computers & Internet
MS Wireless Optical Mouse 5000 - Magnifier
All the buttons are programable and easily accessed through the mouse icon in the startup menue. Click Statup, Click the mouse program icon, a window appears with each of the mouse buttons listed with drop down menues. Click the drop down menue of the button of interest, select one of about 20 choices (in my case "disabled"), click Apply, click Save.
Dec 10, 2008 | Platinum Microsoft Wireless Optical Mouse...
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Jumping mouse
I would take canned air and blow out the optical sensor on the bottom of the mouse. You could also try changing out the mouse pad. Most times when this happens something is causing the optical sensor to sense the wrong movement...i.e. dust, dirt, crumbs. Make sure to give it a thorough cleaning. Maybe use a little Isopropyl Alcohol on the sensor with a foam swab.
Feb 01, 2008 | Microsoft Wireless Optical Mouse USB...
Computers & Internet Logo
David Payne
David Payne
