Our Television works great. For the last couple of weeks our set will randomly shut off. It seems to come back on after it cools down if we fiddle with the power or tv/video buttons. We are thinking that the fix is probably something simple and if we can isolate the component and replace it, we would rather do that than invest in a bran new television. This unit was manufactured in Mexico in April of 2002 and we have only owned it for five years. One thing you should know. It was a floor display model and we got a great deal on it from a friend who worked at the Technique store just before they went out of business.
    Scholar:
  • 124 Answers
Hi, I am Mtoddvan.
Your set goes off after use by itself. I take it it is a (CRT) a large TV not a flat screen?
**Warning even unplugged TV sets have high voltage Capacitors that store power & can hurt or kill you if you even get close to them.**
  1. As silly as this sounds replace batteries in remote. Some turn TV off when they start going dead.
  2. Unplug TV
  3. Most times you will find a solder track on the board that has discolored due to heat I would check here 1st for lose connections or burnt looking components.
  4. Look where the electrical wire comes into to around board may be losing voltage regulator use your nose you can smell a burnt component easily.
  5. Look for cracked components as well.
  6. Check that power button is making good contact in solder board wiggle gently see if it is lose may be losing contact.
  7. These sets are not easy to work on wiring is usually very short & tight Stay away from tube & connections to tube very dangerous.
Please rate & if I can help more let me know I am Standing by. Good Luck! Be careful.
Posted on Mar 09, 2009
  • 6,784 Answers
Hi there, this seems to be a cooling fan Assembly malfunction. the power board sends the electrical current to this device. the connection may be broken or the cooling fan may be dead. i would check the power board first. this may be the central issue then, i would inspect the cooling Assembly for faults. sounds like the power board itself is not receiving any air flow causing it to over heat and shut off.
  • 3,037 Answers
Hi, with projection tvs, they generally collect a lot of dust inside and you should take the time to clean this out every once in a while as it is obstructing air flow and is probably your problem as everything works fine. You just need to remove the back cover and remove the dust. If this doesn't work, let me know what brand and model of tv you have and I can suggest other areas for problems but I'm 99% sure dust is your problem.
Benjamin
  • 744 Answers
Hi....the reason is that some capacitor circuits would have got damaged. if you consult any electircian he would try to remove those lines by means of grabbing a magnet over that shaded area. so that ur problem might get solved.
thank u!!
  • 408 Answers
Have you replaced the bulbs?
Dryer will heat but seems to overheat and shut off.
If that is the style with the small heater in back up top the blower wheel is probably slipping.
Dec 27, 2013 | Amana Dryers
I have a 93 VW Golf. First it started randomly shutting off. I replaced the contacts in the ignition switch and the coil and it ran great for a couple weeks then it started idling up and down, almost dying...
have you tried the crank shaft position sensor ? or if it has one the cam shaft sensor could be one of those if you have access to a diagnostic tester should tell you which
Jun 28, 2013 | Cars & Trucks
Cooling fan on sony wega model kdf50e2000 not working, tv shuts down replaced lamp last week
The set should if shuts down have the power light blink a specific code or number of blinks-----3 blinks?
Mar 26, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have recently bought a sciphone i9 and I have two problems - the first is that it randomly seems to shut down or turn off. Normally will not turn on again until plugged into the mains for a couple of...
Avoid buying Sciphone - they ****. Battery lasts 1 week if you are lucky. Wifi doesn't work. You can't delete useless icons. Won't connect to internet. Don't waste your money on this junk
Aug 14, 2010 | Cell Phones
1999 Honda Accord randomly shuts down while driving
The ignitor in the distributor needs changed. This little guy can cause massive headaches. They work intermittently, but once warm, they knock the ignition spark off.
Hope this helps, vote if you think so thanks.
Jun 23, 2010 | 1999 Honda Accord
HTR-5890 receiver keeps shutting down
for the past month i have been shopping for the perfect home theater system and have narrowed it down to a bose system,a sony system and a paramax p510...i have listened to all 3 systems and have found the paramax to be the better system not a cheaper system but seem more bang for my buck at 3200$,a very powerful tube amp and downfiring sub maxes out at 2000 watts...
Nov 14, 2009 | Yamaha HTR-5890 Receiver
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
RCA L46WD22 won't turn on after being off overnight
RCA are beautiful televisons, what is happening is that when the faulty fan that cools down the processor stops working, your processor over heats and a temperature gage inside reconizes this and shuts down the television. unlike some other models that i choose to remain nameless
*cough sony cough cough* where you need to replace the t.v,
RCA has a safty feature that allows the t.v to shut down with out it doing any harm. Ok folks, this is the easyest answer that i am going to ever give anyone.
All you need to do is Replace the FAN! that fan that cools down the processor to allow the fast movements to give the vibrant pictures in stunning accurate pixle compounds. it will cost about $50 for the fan and $200 for the guy/girl to install it.
So there you are a complex problem with a simple answer. you are one lucky person, you choose the right television the only factory defect was the fan. your t.v should last 15years without any serious problems.
I hope this has helped you folks. i am called the flat pannel Guru in my buisness.
Jun 16, 2008 | RCA L46WD22 Television
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
