Question about Laguna Tools Platinum Series 17" Variable Speed Drill Press
I have a powermatic drill press model 1150A the varible speed seletor will no longer turn,I can only use it at one speed any thoughts as too why it stopped working?
  • Anonymous Mar 22, 2014
    Low Speed does not work, looking for a wiring Schematic
There is a little bearing that rides in a cam for adjusting the belt tension. It's probably shot. Good Luck!
Posted on Jun 09, 2009
I am searching a good drill press.someone suggest me this drill press Powermatic 719T Mortiser.Is it good?need advice.
The Powermatic 1791264k Model 719T Tilt Table Mortising machine, works excellent and it is a very good equipment. I have no regret in purchasing this machine.
More details Make elegant choice with Powermatic 719T Mortiser Review
Mar 13, 2018 | Powermatic Drills
Change jacobs 33 chuck powermatic 1150a
In most column drillsis a narrow rectangular recess above the chuck when it is rotated slightly downwards
therefore you should have one of these auxiliary tool
At least the wedge
Have not seen another system to remove a drill spindle
Feb 27, 2016 | Powermatic 1150a Variable Speed Drill...
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
Removimg chuck powermatic drill press 1140b
Powermatic is the great drill press. If you need any information about the Powermatic drill press go to the link Make elegant choice with Powermatic 719T Mortiser Review
Apr 10, 2012 | Powermatic 1140 B,f 14 " Drill Press...
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
I have a composit kitchen with knock outs for 4 faucets. How do I knock them out?
Do NOT try to knock them out! The correct way is to drill them out as needed for your particular faucet. Refer to your installation instructions for your faucet to determine which holes need to be drilled out. There is a school of thought that it is best to drill them all and use a hole cover on those you don't use since once the sink is installed you will no longer be able to drill them at exactly factory locations.
You will need a 1-3/8" hole saw (my preference is Lenox brand # 30022), an arbor (a special drill bit for the hole saw Lenox brand # 2L), and preferably a varible speed drill.
Turn your sink upside down and place onto a clean padded surface to protect the finish and is also a padding that you can bear to throw away. Locate the center of the hole to be drilled. If there is no dimple from the manufacturer at dead center, you will have to give it your best guess. Mark that spot and with the arbor securely mounted into the hole saw, begin drilling at 1/4 to 1/2 speed of the drill, until the tip of the arbor had drilled completely through. Remove the hole saw and turn the sink right side up. The hole that the arbor made in now called a pilot hole and will guide your hole saw perfectly. By drilling from the top side you eliminate any chipping. Insert arbor into the pilot hole and begin drilling using light to moderate pressure until the hole saw has drilled through. Be careful! As you sense you are nearly through the drilling, only use light pressure so you don't lose control of the drill when the saw pops through and accidentally smack your sink.
May 31, 2010 | Swanstone KSDB-3120 Compact Double Bowl...
Clunking when lowering the spindle
Try checking to see if the front pulley cluster locking grubscrew is tight, I had a similar problem on mine.
Mar 15, 2010 | Powermatic 1140 B,f 14 " Drill Press...
Spring return
paste this link into your browser address bar
http://www.toolsandmachinery.com/powermatic-parts-5882/powermatic-drill-press-parts-6903/powermatic-2800-parts-6904/
thats the diagram and parts listing for the only available powermatic drill press ( 2800) , if its an older model you might find the parts on ebay , i have in the past used a recoil starter spring but it can be a pain to modify the spring to suit .
hope this helps , if it does please vote :)
Nov 10, 2009 | Powermatic Drills
Laguna Tools Platinum Series 17" Variable Speed Drill Press Logo
778 people viewed this question
Top Laguna Drills Experts
Are you a Laguna Drill Expert? Answer questions, earn points and help others
