Question about Dryers
This a stacked washer dryer unit. Dryer will not heat. The heating element looks good. Checked with an Ohmeter and it tests positive for complete circuit. Can the hating element stgill be bad?
  • 5 more comments
  • gmoose1 Mar 10, 2009
    Okay, I tested the voltage at the contacts to the heating element and found no voltage coming into the heating element. What is the next step to diagnosing the problem with this dryer.
    I know where the thermal fuse is on the unit. How do I determine if this is okay?
    any way to test this part before replacing it?
    Again the question is. Anyway to test the thermal fuse to determine if it is the problem?
    I have voltage at the power source on both legs. but no voltage at the element.
    No voltage at the heating element
    I tested the thermal fuse and found it to be bad. Bought the part locally for $15.89. The dryer is fixed and working. FixYa.com is a great service. Thank-you Ginko
  • 916 Answers
The control board in the machine needs to be replaced.
Posted on Mar 10, 2009
  • 294 Answers
Suspected Components:
1. Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
2. Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
3. Hi limit Thermostat (located on the heater box closest to the heating element leads) – Resistance reading of 0 ohms.
4. Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, approx. 7 ohms across the other.
5. Bad Heater Relay (usually located in the console) – this is not equipped on all model dryers. However, on dryers that DO have them, this acts as a switch and turns the heater circuits on at the push of the START switch.
  • Dryers Master
  • 19,396 Answers
To start, you do not test an heting element by reding voltages, even if reading voltages you can understand if heating element has continuity.
You test theating element and termal fuse in the same way. You test them for continuity.
To test continuity you set the multimeter on ohm scale and test impedance at the two contacts on termal fuse or element.
If impedance is infinite then termal fuse is bad, in same way you test element.
If you have no heat , but the machine tumbles, then test termal fuse, check if the fan is running, and test heating element for continuity.
By reading volts to heating element you tested the control board and wiring to element, that usually is the last part to test in order.
Always unplug the appliance before testing for continuity.
  • Ginko
    Ginko Mar 10, 2009
    If you have no voltage at the element then test termal fuse, if termal fuse is also good then tst and replace the control board.
    To test the control boardand wiring harness. To test control board, inspect it visually, if you find a bulged capacitor, then board is bad, also test all resistors on control board for continuity.
  • 6,784 Answers
OK, if the time delay fuse(thermal) is bad, you will not be able to retrieve a reading during test. this is a common issue when the element is malfunctioning. replacing this time delay fuse will fix this issue. If the element has good readings then, its most defiantly the thermal fuse. make sure you replace it with a time delay. regular fuses wont work.
  • Michael Masters
    Michael Masters Mar 10, 2009
    continuity test is best.
  • 201 Answers
Test between the fuse and ground - You should have voltage on both sides of the fuse.
  • John Aman
    John Aman Mar 10, 2009
    Or as mildcooksey said, you can test it for continuity - just disconnect the power to the dryer and the leads to the fuse first.
  • 10,515 Answers
There is a thermal fuse in your machine which may be open or you may even have voltage issues. Try turning the breaker off and then back on and see if it heats then.
More likely its thermal fuse.If you stand on a chair, and take all the screws off the top cover on the dryer, and remove the top cover, you will see the thermal fuse on the top left hand corner. It is the size of a dime, and has 2 wires going to it. This is a easy one.
Thanks.
  • 4,369 Answers
Make sure you have 110 volts on each leg coming from the power source. The motor works on one leg, the heater element the other leg. If you have voltage, it is probably the element.
  • 163 Answers
No npt unlessit has welded itself to cage.you may want to check and make sure you are getting 220 to the dryer.and what brand is it.most have a thermal fuse and if fuse blows it wont heat
  • 1 more comment
  • mike cooksey Mar 10, 2009
    check your thermal fuse located on heater cage.it will have 2 wire and is the smallest looking one of the 2 on cage
    you can test it by using continuity.
    if it doesnt read continuity it is bad.
  • 2,984 Answers
I don't think so. There are a few things it could be but a thermal relay would be the best bet....simple to change, located on the tubing that the heating element is and has two screws holding it on. Less than $30 for the parts. It happened to my dryer just two weeks ago.
  • Greg Bernett
    Greg Bernett Mar 10, 2009
    You can check the continuity between the pins by removing the piece and checking the contacts....but you remove it...you can go ahead and replace it. How is your cord on the backside of your unit? The portion that goes into the dryer?
  • Greg Bernett
    Thermal fuse.
  • 3,037 Answers
If there is voltage at the element, then the element is bad, no voltage would make it good and have a different problem, probably on the control board. Let me know how much voltage you have when you try running it. You might have to trip some safety features to test it.
Benjamin
Posted on Mar 09, 2009
  • Benjamin Patri
    Benjamin Patri Mar 10, 2009
    alright so no voltage, well you can try using a voltmeter and see if there is any voltage across the fuse or just buy another fuse since it is fairly cheap and the most common problem other than the element
    Brigadier General:
  • 8,619 Answers
Hi!
Have you checked the thermal fuse? It can also cause this to happen.
  • Rylee Smith
    Rylee Smith Mar 09, 2009
    Please tell me the model number so that i can describe the location of thermal fuse and other details. Thermal fuse
    Top Expert:
  • Dryers Master
  • 77,499 Answers
When the element is turned on do you have line voltage at the element? I have replaced many elements and have only seen one that "looked Bad" the outside of the element is just a cover, the wire heater is inside the outer metal sheath, the elements are cheap and they are the most common thing to fail in any appliance that uses one.
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
No heat in dryer. This is a stacked dryer/washer combo. The dryer is electric. The drum turns and timer works but there is no heat in the dryer or exiting the vent. The washing maching beneath the dryer...
The element to heat the dryer has gone out. You removed the back of the dryer to remove lint you will need to remove the back of the dryer again to access the heating element. It is in the lower left or right hand corner (depending on model) and looks like the inside of a toaster oven small thin wires. Take the assembly out (make sure the unit is unplugged always) get the model and serial # and purchase replacement from an appliance parts house.
Good Luck hope this helped you some
Dave
Jan 23, 2010 | Dryers
No heat in our Whirlpool Dryer Model LTE5243DQ3. Tested both fuses and all the wires have power. Still there is no heat. The parts tested were 3398128 and 3404154. Are we missing somthing?
There is what's called a high limit in dryers. It protects the unit in case of over heating. It usually is small, has 2 wires connected to it. Check continuity. Or' check your heating element for breakage, or continuity.
Dec 23, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer wont heat up
my dryer wont heat up the element tested good
Sep 28, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Whirpool twin thin no heat
Make sure you have 220 volts first at dryer. Heating element is on back of dryer. You'll need a test meter to see what's wrong unless you can see broken wire in element itself. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool LTE6234D Top Load Stacked...
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
41 people viewed this question
Top Dryers Experts
