Question about HP Pavilion dv9000z Notebook
UNPLUGGING COMPUTER DOES IT HURT TO UNPLUG COMPUTER FROM WALL OUTLET WHEN I AM THRU USING IT IN THE EVENING- I DID THIS LAST NIGHT AND SCREEN ACTUALLY CAME UP FASTER THEN JUST USING COMPUTER TO SHUT IT DOWN ONLY PROBLEM WAS THAT IT TOOK A BIT OF DOING TO GET MY INTERNET (WIRELESS) on AGAIN.??? from JUDY
    Sergeant:
    Champion:
  • 357 Answers
Like RSBennett said, it is a good idea to unplug your laptop when not inuse and if you run your battery down regularly, as it will last longer, by doing this you will NOT lose any of your files, as this is also recommended by ALL manufacturers.
I hope this helps clearifies your question.
Good Luck.
Posted on Mar 09, 2009
  • 55 Answers
You will NOT lose files by unplugging after you shut down your laptop.RSbennett is 100% correct! good job!
    Scholar:
  • 54 Answers
No, it's not a problem to unplug your notebook computer from the wall when shutting down for the day. In fact, leaving your notebook plugged in all the time is bad for your battery. Your battery will have a long life if it is plugged in to charge and then unplugged while using the computer, and allowed to discharge fully (or down to 10% or so), and then plugged back in.
Hope this helps.
  • 294 Answers
I WOULD'NT RECOMEND DOING THIS EVERY TIME YOU COULD LOOSE SOME FILES OVER TIME
My magnavox crt is about 10+, worked great.Last night,the screen remained black, and sound was static. Tried unplugging, held the power button, ran a new cable line from working tv.No lights in back.
I hope I can help. I would first try another outlet.
  1. another power outlet
  2. check the cable from the TV to the wall or cable box
  3. Check the TV Input channel, make sure you go through each source input to verify which tv/video input is the correct one.
Jul 28, 2016 | Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
When I turn the unit on it clicks but fan doesn't move?
i have fix fans by lubricating the shaft there is usually a support that get gummed up and it will not hurt putting wd 40 in an electric motor otherwise the motor is bad or the overload burned out every electrical motor has an over load where it is heat (thermal) or others i can not think of right now some are fixable by replacing a diode
May 17, 2014 | TPI E4315T Wall Mounted Panel Heater
Red light flashes 5times continuously doesn't power on started last night
try unplugging it from the power outlet, hold and press its power on switch for 10 seconds, and test it again. you may also want to try another power outlet.
Aug 08, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
I bought a Uniden DECT 1035 last week and it has been working fine until yesterday when the screen went blank and only the status light was glowing. I charged it all night but still nothing has changed....
I would take it back to the store, there is a communication problem between the base and the remote phone, the only thing I can suggest is unplug the power and phone jack from the wall outlet for 30 seconds to see if the Uniden can reset.
Feb 10, 2011 | Uniden Cordless Phone
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Was watching a movie on my computer last night and all the sudden the screen started turning off and on with no picture when it was on. Has the monitor gone bad or is it a video card issue?
The simple way to check if this is a Monitor issue or not, you can unplug the monitor from the Computer and connect it only to the power outlet. If it gives you a "No signal" screen or goes through any sort of other Self test, Your monitor is fine. You can also check if the power led is blinking Amber or Green. A blinking Amber LED while the monitor is only connected to the Wall outlet indicates the monitor is faulty.
Thank you for using Fixya
Oct 08, 2009 | Dell E173FP 17" LCD Monitor
Does it hurt to unplug my desktop every night?
It uses a tiny amount of electricity from the CMOS battery but really no problem at all. I turned them off for years w/o any problems.
Mar 18, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
IF I UNPLUG MY COMPUTER FROM WALL OUTLET AFTER USING IT IN EVENING SHOULD I '''ALSO UNPLUG''' MY WIRELESS ROUTER??
Hello, there is no need to unplug anything, you may want to buy a power strip and plug the computer and router into it then you can switch it on and off, (that is if your doing this to save power)
Mar 09, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
