Question about Refrigerators
New 700BR freezes everything in it. Worked ok for
New 700BR freezes everything in it. Worked ok for 2 days, then wife lowered temp to 36F, now everything freezes no matter what temp we set.
  • 400 Answers
Sounds like a stuck thermostat, you can try to tap it and this may "unstick" it, or you would need to replace it.
Posted on Mar 09, 2009
Fridge 700br 2 drawer Built in unit over cooling ,
You should consider a service call. This can happens when the thermostat is failing or when the refrigerant is under charged.
Mar 19, 2015 | Refrigerators
Engine overheat and no heat
Maybe your radiator is clogged.
Mar 12, 2017 | 2001 Nissan Sentra
Why is our fridge frozen all the time?
Hi!!
The evaporator fan (little fan in freezer), is the one that blows cool air to the fridge. If your evaporator is freezing up, it could be due to the thermostat set too high, and the fridge control set too low. Set freezer temp. one number lower, wait 24 hrs and check, if evaporator still freezes, lower it one more setting. If temp in fridge is OK. leave it alone, or adjust accordingly.
Let me know how it worked out.
Good Luck!!
Mar 28, 2010 | GE GSS25JFM Side by Side Refrigerator
Overheating
water pump ,its a plastic impeller and its loose on the shaft ,,,,,had one a while ago exactly the same but the first time i came across this on a saab i done the same as you ,changed everything ,felt a right you know what
Sep 01, 2009 | 2002 Chrysler PT Cruiser
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
2005 supercharged monte carlo has very little heat.
170 is ok, this should provide excellent heat output, your problem is one that is common on many newer car, it is caused by the air temp control blend door actuator motor, I hate this system because it is prone to failure and requires the removal of the dash to repair/replace the part.
Dec 24, 2008 | 2005 Chevrolet Monte Carlo
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Dec 17, 2006 | Frigidaire PHSC39EESS Stainless Steel Side...
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
