Motor sounds loud and high pitched. Suction seem ok, can't find any blockages. Cleaned filter at top of removable canister. Exhaust seems hot and low. Can there be a blockage within the motor housing?
When switch to carpet, the difference is that the brush roller turns. When it is on hard floors setting it doesn't. Remove the base plate, remove the brush and the belt. There is likely something wrapped around the drive spindle or clutch.
The high pitched whistle that you are hearing from your Rigid shop vac with a long hose may be due to several reasons. Here are some possible causes:
Airflow restriction: When you use a longer hose with your shop vac, it increases the airflow resistance, which can cause a whistling noise. This is because the motor has to work harder to maintain suction, and the increased resistance can cause turbulence in the airflow, creating the whistling sound.
Hose size: The size of the hose can also affect the whistling noise. A smaller diameter hose can increase airflow resistance, which can cause the same issue as a longer hose.
Clogs or blockages: If there are clogs or blockages in the hose, this can also cause the whistling noise. Check the hose and attachments for any obstructions, and remove them if necessary.
Vacuum motor issue: In some cases, the whistling noise may be due to a problem with the vacuum motor itself. This could be caused by a damaged impeller, a loose fan blade, or other issues with the motor.
To fix the issue, you can try the following:
Shorten the hose: If possible, try using a shorter hose to see if the whistling noise goes away. A shorter hose will reduce the airflow resistance and may help to eliminate the noise.
Check for blockages: Inspect the hose and attachments for any clogs or blockages. Remove any obstructions that you find.
Clean or replace the filter: If the vacuum filter is dirty, this can cause airflow resistance and make the motor work harder, leading to the whistling noise. Clean or replace the filter as necessary.
Check the vacuum motor: If none of the above solutions work, you may need to inspect the vacuum motor for any issues. If you are not comfortable doing this yourself, you can take the shop vac to a professional for repair.
hi, what this points towards is a blockage either in the pipe or where the filters are, if you dont unblock it then it will over heat and blow the motor.
This is a very common fault for this make of vac and they dont tend to last long anyway.
Your best option would be to remove the part you empty and take out any filters you can get access to give the filters a good clean by banging them on a wall to remove any build up of dust and hair.
The have a look at the pipe try and take the pipe off the usual place for blockage is where the pipe goes into the vac so check here for blockage its usually just a build up of stuff you have vac up that has caused a blockage.
as you have no suction from the hose you would then have no suction at the floor part so dont try using it like it is . you need to remove the hose its either screwed in or held in by two plastic clips that you can push with a screwdriver once you have undone this you should be able to see the blockage.
Let me know how you get on or if you need further assistance ok
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
