Question about Goodman CPLE24-1 Air Conditioner
I just turned on my ac for the first time this year. I found leaking on my carpet. I had to change my filter and found ice on my pipes. also the area around the unit was damp. Did i fix the problem by changing the filter or is there suppost to be a filter under my filter. I have a model ar30-1 Thank you
  • 3,361 Answers
The ice buildup comes from low refrigerant or poor airflow.
Is your indoor fan runnig OK?
Are your evaporator coils clean of dust and dirt?
If fan is good and coils are clean, call a service tech to check your refrigerant charge.
Posted on Mar 09, 2009
ICE MAKER NOT MAKING ICE AND LEAKING
Your ICE MAKER may be blocked in some way [CLEAN water inlet lines &/or replace the in-line FILTER] OR the THERMOSTAT could be faulty [in an older unit]. Check all in-line water pipe connections for leaks AND/OR damage from any rodents you may have had in your home. This is particularly prevalent in tropical areas and when inlet lines are made from any type of nylon/plastic material. ALSO check your DOOR SEALS as this will sometimes cause this type of problem. It is also possible that the INSULATION in your older unit may be breaking down [you will notice moisture/"sweating" on the outer case surfaces which would indicate this type of fault].
Sep 21, 2014 | Frigidaire Refrigerators
Tsb bulletins
if it is loosing coolant and smells like such in cab it is likely that the heater box or hoses has a leak easy to find with a coolant pressure test. if it fails it can be temp bypassed by joining the in and out hose that goes thru the fire wall. either that or your air con may have a blocked moisture pipe this will generally leak on floor when cornering and ac is on .. the fix is easy if you have access to a dust gun and in short bursts blow rubber pipe where condensation from air usually escapes out onto the road from . also recommended change the pollen filter in the cab it is in the ac system to purify the air and when it gets blocked that can cause this problem as well.
Sep 05, 2014 | 2005 Mitsubishi Eclipse
Car exhaust in the cabin
CHECK EXAUST FOR LEAKS.U CAN DO THIS BY HAND!!!!ENGINE RUNNING GO TO THE BACK OF THE CAR AND CLOSE THE END OF THE PIPE WITH YOUR HAND.DONT WORRY IT IS NOT HOT!!!IF U HEAR A HISH UNDER THE CAR U NEED TO CHECK THE EXAUST FROM FRONT TO END FOR LEAKS.IF NOT WHEN U RELEASE YOUR HAND FROM THE PIPE U WIL GET A POP SOUND.IF SO CHECK POLEN FILTER AND CHANGE .ONCE A YEAR U NEED TO CHANGE THAT FILTER.ALSO CHECK RECYCLING OF THE AC SYSTEM.
Mar 03, 2014 | Volkswagen Passat Cars & Trucks
The ice maker is not working. How do I check the tubing for ice blockage?
I found with most things that stop working suddenly, I first recall any recent changes/ updates. What Electrical additions plugged in or unplugged? Any visitors who might have flipped a switch, tinkered with or bumped the devices controls? this works for computer software too. What was recently installed or removed?
1. If the Icemaker metal arm is up, Ice Maker thinks it's full, Answer: lower the arm
2. Visually check the plastic water trough that feeds water into the ice tray. Careful never to use sharp metal to remove ice from it, since gouges or scratches will remove the teflon coating, allowing water to freeze in the scratch tracks, therefore building up ice to block flow again.
2. If the water supply is kinked, no water can get through. Answer: Carefully pull Fridge away from the wall far enough to inspect the water line for blockage. (Warning: un-kinking copper coil can lead to leaks and breaks!)
3. Water supply has been turned off or blocked at the source. A: Back track to the source for blockages, breaks or if turned off. The water is usually supplied via 1/4 inch saddle valve attached to a vertical cold water pipe and by code should be accessible. Most are found attached to the cold water inlet pipe above the hot water heater. (Warning: these valves commonly leak when turned off, since they are always in the 'open' position for years.)
Apr 23, 2011 | Kenmore 50522 / 50524 Side by Side...
2005 Toyota Corolla - car smells after rains
Look under the passenger side of the dash, behind the carpet. Feel the back side of the carpet for dampness. If so, try this: In the same area, look for a black rubber hose that comes from the heater plastic box, and pokes thru the firewall. See if it is plugged up. This is the drain pipe for the AC box, and the cowl panel if the side drains are plugged up. Try that, and please get back to me.
Sep 16, 2009 | 2005 Toyota Corolla
Wet carpet in 2001 Chrysler Voyager minivan
have a look could be cracked casing where someone has kicked it ,if its plastic then repair with matted fibre glass filler ,or check rad in case its coolant leaking from the heater matrix ,quick tip put a couple of pairs of molegrips on heater pipes and see if it still leaks
Jun 29, 2009 | 2001 Chrysler Voyager
04 trailblazer AC leaks
Rather than pay the dealer $350+ to fix this, I found the "L" shaped drain hose behind and interior to the front passenger tire (I let the car idle with the AC on and waited for a drip. On my back on groud I reached in and found the drain line and it came off i my hand and about 4 oz of water and some decayed matter floowed out. I reaced back in and found the hole to which the L line was attached. It was a rubber fitting on the end of a metal pipe. The fitting came off easily and then about 8 oz of water flowed out (carpet had been soaked for two days). I reattached the L drain line and noticed that inside the fitting was about 1/4 tsp of "mulch" - decayed leaves, pollen, etc. Reattacted the fitting and water now flows freely out the drain. And yes, its a very high humidity area - Houston, TX. And if you live anywhere near here you know about the intense yearly dispersion of Pine tree pollen. I thisnk that accelerates the blockage. Happen about every 2 years. (Third time for me. First two I let the dealer over charge me for this effort. BE SAFE WORKING UNDER YOUR CAR!
Jun 22, 2009 | 2004 Chevrolet TrailBlazer
FILTER LEAKS!
go to the hardware store or even a home depot or lowes and get some plumbers pipe dope........a small tube will be plenty. remove the filter and dope up the areas where the two components hook together. it is magical.
May 20, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Leak onto floor passenger side from neck of ac drain through firewall
it sounds like your heater core is busted. you will have to go under the dash to get to it and replace with a new one
Oct 11, 2008 | 1999 Jeep Grand Cherokee
Air Conditioning Unit is leaking badly, has mold and ice.
soundls like the condensate drain is clogged and coil is dirty. look for a plastic pipe inlet where water would flow to.. you may be able to clear it by blowing it out with compressed air. you can also pour bleach into it to address the mold problem. if the coil is icing up it is because it is dirty. to verify this, let the unit run in ac mode for about an hour and check to see if you have air flow from the vents. if you do not, then the cooling coil is covered in ice, thus blocking air flow. you should have a qualified ac person clean the coil and check the refrigerant charge on the unit. one thing to consider, change your ac filter often, at least once a month in hot weather.
Sep 14, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
166 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
