Question about Dishwashers
Dishwasher water comes out of air gap
Plug is out and clear in garbage disposal.
7/8'' discharge line is clear from air gap to garbage disposal.
5/8'' inlet line from dishwasher is hooked to 5/8 side of air gap.
Just installed new air gap and diswasher still drains through air gap!!!!
WHY???
  • lmcnair4 Mar 12, 2009
    Tried your idea, but water still came out of the air gap.
  • 74 Answers
Ur discharge line is to low...try to make a loop
Posted on Mar 10, 2009
  • Cesar Quant
    Cesar Quant Mar 16, 2009
    okay did u check When
    connecting drain line to disposer,
    check to be sure that drain plug has
    been removed. DISHWASHER WILL
    NOT DRAIN IF PLUG IS LEFT IN PLACE, and dont forget to make a loop with 32 " minimun of high
Water is coming out of air flow gap. I installed a new air-flow gap and all new lines from air flow gap to sink (except the line from dishwasher to air flow gap) and i still have water coming out the air...
The leak in an air gap is usually caused by a clogged sink discharge line. Most of the time this is connected to the garbage disposal and there is food particulate in the drain hole where the dishwasher drain from the air gap to the garbage disposal connects.
Pull the sink connection hose off and clean the hole thoroughly. You can try testing the dishwasher/ air gap by placing the disconnected hose into a bucket during the pump out period. It should not leak. After this test...reconnect the hose to the sink connection.
If it is NOT connected to the garbage disposal then remove the hose and clean out the hole where the connection is made. This is a common problem and easily resolved by the user.
Thanks for using FixYa.
Kelly .
May 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Water isn't draining.
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Thanks for contacting fixya.com
Nov 11, 2009 | GE Nautilus 24" Built-in Dishwasher
There is a horrible smell inside. We've taken the
cycle the dishwasher, and after it fills with water, dump 6 cups of bleach in there and let it contunue. just before it starts to drain, stop it and let it sit for an hour. restart dishwasher and let it cycle thru.
Oct 10, 2009 | Dishwashers
Once my dishwasher completed the cycle there is no water but after two or three days the bottom of the dishwasher fills with the dirty water. what could be the reason? I have garbage disposal and one pipe...
You must have your dishwasher connected directly to the garbage disposal and not through an air gap. What is happening is when you disposal fills with water it is siphoning through the drain hose back to the dishwasher. If you sink has a spare hole on the deck install air gap and run dishwasher drain through air gap first. Otherwise make sure you run Garbage disposal often so that water does not get slowed and build up inside.
May 11, 2009 | Frigidaire 24 in. FDBB944C Built-in...
GE Dishwasher 2200 series - water comes out airgap
take the air gap apart and clean it out. also clean hose from air gap to garbage disposal.. if the garbage disposal is new take it down and remove the plug where the drain hose from the air gap connects to it..
Feb 13, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Hot point dishwasher
If the disposal is new, the hole was not punched out where the hose connects. If the disposal hole is open, the hose is clean, then the air gap should be replaced. Its cheap and not hard to do, saves headache.
Mar 15, 2008 | Dishwashers
Dishwasher not draining
I had water at the bottom of my 4 year old plus dishwasher and of course I thought the worst. Did the pump go out, bad impeller, or what else could it be! I started with the easy stuff first and disconnected the drain lines. The drain line runs from the dishwasher to an air gap mounted to my sink, which keeps the drain line from getting an airlock. From the air gap device another larger line runs to the garbage disposal. I used an 8MM wrench to loosen the clamps enough to pull the drain lines off and drained them into a bucket. There really wasn't any resistance to water flow and no real chunks, I was disappointed.
I then took the actual air gap out of the sink by removing a large plastic nut and pulling the devise out from underneath the sink. When I inspected the air gap I saw a wad of hairy, feathery plastic stuff blocking the flow of water. I took the chunk out, reassembled everything and it works like new again.
It is a very easy fix and now even the area under the sink is clean to boot.
Jerry
Sep 03, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Bad smell
It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
May 18, 2007 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
398 people viewed this question
Top Dishwashers Experts
