Question about Toshiba Satellite A305-S6883 Notebook
LCD replacement Trying to install new screen. Cannot find instructions on this exact model to get the old frame off in order to properly install the new screen. The lower portion of the bezel is still on - preventing the frame from being completely removed. How can we take that off? The hinge cover is blocking access to the plug so we cannot install new screen plug into the inverter. Other similar models do not have this same type of hinge connecting screen to keyboard, and mine does not show any place where any screws would be - it's flat and smooth. If you look at a photo of this model of laptop you'll see. Please help if you can!! Thanks, Nicole
  • kuhn805 Mar 09, 2009
    we have the plastic frame off, all except that one spot on the bottom where it is connected at the base. We cannot see ANY plastic covers to remove to reveal screws - the ones around the rest of the frame were easily identified..however the base seems to be completely connected with no identifyable covers for screws to complete the dismantle. If you look at my EXACT model online at a photo - close up at the way the base connects, you'll see what I'm talking about. I realize there has/should be a way, but it's not clear AT ALL!
    thanks...
  • Toshiba Master
  • 32,281 Answers
The LCD screen is fixed to the base of the laptop with screws at the hinges.
Some screws are hidden behind small stuck on plastic covers, you need a thin sharp blade to lift them to reveal the screws. The frame around the LCD screen most likely held in place by plastic clips or stuck on with double sides tape. Slide a spatula between the LCD and frame and gently prize the frame free, take care not to break the plastic frame.
Once you remove the frame there are screws that fix the LCD to the lid of the laptop.
You need to lay the screew flat to unclip the plastic cover to expose the hinges and the video cable between the screen and motherboard. There are usually screws holding this cover in place.
Posted on Mar 09, 2009
Remove and replace LCD screen
That is so easy task
remove the tv cover . Then unplug the sockets from the tv boards
then take the screen with frame outside. And remove the feame carefully. By a suitable tool or rigid card so you don't leave wear sigbs at the screen frame
the frame is installed on thr screen by clips.so carefully at the places of the clips the frame will be removed
now install the new lcd sceen at the frame. Press the frame at the clips places untill you hear the sound that it fit on the screen
and install the new screen sockets at same places where the old were installed
important note. Sign tge sockets before installing the new screen. Put number for same socket on the screen and thr tv board. At tge male and tge female plug
May 07, 2015 | Video Cameras
Replace power supply for mitsubishi LT-52148
see this instruction. God bless you
    • 1
      Unplug the monitor power cable. You should never attempt to disassemble an electronic component without first detaching it from its direct power source.
    • 2
      Remove the screws from the back of the monitor and along the edge of the screen. Depending on manufacturer and model, LCD monitors will have screws located on different parts of the monitor's body. Once the screws are off, use a flat-tipped tool, such as a knife or a screwdriver, to pry the monitor open by dislodging the two halves; be careful not to tear wires connecting the two halves.
    • Sponsored Links
    • 3
      Locate the power supply unit and take its metal casing off. Once again, different models of LCD monitors will have the unit placed in different locations. With the casing undone, unplug cables running from the power supply to other internal components. Mark the cables that you unplug from the power supply--you will have to plug them back in to the new unit.
    • 4
      Dislodge the power supply from its dock. In some monitors you might have to undo screws that hold the power supply unit in place. Remember the orientation of the unit as it was placed, because you will have to insert the new unit in exactly the same way.
    • 5
      Insert the new power supply into the dock and screw it in place. If you do not have a new power supply, read the label on the existing one to order a new one from the manufacturer or from a third-party supplier. Obtain a power supply unit that is compatible with your LCD monitor; never try to use a generic spare. After installing the new unit, plug in the cables exactly as they were in the old unit.
    • 6
      Put the power supply casing back on and reassemble the LCD monitor frame. Gently clasp the two halves of the monitor shut, making sure you have reattached all cables that you unplugged to take the monitor apart. Close the casing, tucking away all cables neatly so they do not get in the way of the monitor casing.
    • 7
      Put all the screws back on. Once done, you should have no leftover pieces (screws or cables).
Read more: http://www.ehow.com/how_6165539_replace-lcd-monitor-power-supply.html#ixzz2ZJV8TbYP
Jul 17, 2013 | Mitsubishi LT-52148 52-Inch 1080p LCD HDTV
How to replace a cracked screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 06, 2012 | Computers & Internet
Lcd replace
You should the installation instructions with the new lcd screen
Hope this helps
watch video
Nov 04, 2012 | Computers & Internet
Screen is non-functional and irreparable
hope this helps
Sep 17, 2012 | Computers & Internet
How do I remove old screen and head and replace with new
You will find the correct screens for model MS280 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp67-ms2-series-foil-screen-set-p-233.html
You will find installation instructions at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_23_2.jpg
If replacing the foils is difficult for you, you may want to consider ordering the foil and frame assembly. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms2280-ms2290-ms2390-head-assembly-p-391.html
Dec 31, 2010 | Remington MS280
How to replace a lcd screen on a notebook
Hello
Here is the detail pictorial view of replacing screen of dv6000
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
Good Luck, and do rate the solution if got help
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Replace driver side mirror
Go to local auto glass shop or auto supply store. Order a new mirror (not expensive). Ask also for the proper adhesive.
Put on some thick gloves (use pliers if needed) and remove the old glass.
Remove old adhesive from the mirror frame.
Apply adhesive to frame
Put new part in place and hold for a few seconds (read adhesive instructions).
That is it.
Please rate if this helps give your direction.
Jun 02, 2009 | 2002 Chrysler Town & Country
LIGHT ISSUE ON GBA SP
The new screens being sold are for the Japanese model that is why they fit a bit differently. Also they are just not as bright. There is nothing you can do really to fix this. As you can see on your old screen there is a black frame around the screen, this helped to keep the light centered into the plastic over the LCD and make it brighter, the Japanese version doesn't have this. The LED used is also not as bright on the replacement screens.
Mar 19, 2008 | Nintendo Game Boy Advance SP Console
Toshiba Satellite A305-S6883 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
