Question about Whirlpool DU930PWS Built-in Dishwasher
Dishwasher wont drain - Whirlpool DU930PWS Built-in Dishwasher
  • 6,784 Answers
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 25, 2009
    Sergeant:
  • 197 Answers
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on May 31, 2009
Items like shirts and lawnmowers or food particles like weeeeners and beans..heeuh heeuh heeuh
Posted on Jan 22, 2010
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
Doesn't drain after washing dishes
Thank you for contacting fixya.com.
There are various factors when a dishwasher wont drain water completely.Such as clogged drain hose,worn belt,pump assembly,bad motor,defective timer,drain valve etc.Please check the bellow links to read the article thoroughly to troubleshoot your problem:-
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#thewaterdoesntdrainfromthemachine
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Roper 24 in. RUD3000 Built-in Dishwasher
Water is not drain completely after wash.
Jun 01, 2011 | Miele 24 in. G870 Built-in Dishwasher
Ge profile dishwasher wont drain. i have already replaced the drain motor. Why wont it drain completely
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 12, 2010 | GE Dishwashers
Dishwasher wont drain,i cleaned the filter but still wont work
heatman101
Sep 07, 2010 | Kenmore Dishwashers
Diswasher wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 23, 2010 | Maytag Dishwasher
Dishwaher wont drain-checked drain hose and its clean
The problem is most likely the drain valve. It is electrically operated and with your problem it is the most common cause.
If you need more help, post a comment.
Thanks,
Tim
May 29, 2009 | Kenmore 16719 Dishwasher
Bosch dishwasher wont drain
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Jan 26, 2009 | Kenmore 15129 Built-in Dishwasher
Whirlpool DU930PWS Built-in Dishwasher Logo
483 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
