Maytag MAH2400AWW front loader door is locked. Error occured during the spin cycle.
  • randrhyde Mar 27, 2009
    Hard to believe that a maytag repair man can not come and fix for 7 days, I thought they all sit by the phone waiting for it to ring. My clothes will end up going into the garbage for sure.
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Mah2400aww door won't open
Wax motor (Door lock mechanism) & or control board burn out. Door can be unlocked with nylon string situated in soap power dispencer at front.
Dec 12, 2013 | Maytag MAH2400A Front Load Washer
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
Front loader won't balance on spin cycle. thumps and walks almost every time. Spins ok if empty. This is a new problem (last month or so). Machine is less than 2 years old. Maytag model MAH2400AWW...
The problem may be you might be cloths will be less quantity kindly check the cabinet of the unit and the upper spring is be elongated kindly replace the spring before that check the cabinet any revit has been cutted off
Dec 24, 2009 | Washing Machines
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Washing Machines Logo
478 people viewed this question
Top Washing Machines Experts
