I want to move the outside unit of our split system aircon.
If I disconnect the gas pipes will the refridgerant escape or will it be retained in the compressor.
  • 108 Answers
It will definitely escape. In fact, allowing that gas into the atmosphere is kind of illegal, as well as really expensive. An HVAC repairer has the equipment to remove the gas while keeping it trapped, do any plumbing needed to move the unit to it's new location, and then recharge the unit with the same freon (though you might need to add some to account for the additional run of pipe). Also, the electrical box will probably need to be moved.
Posted on Mar 09, 2009
How do I disconnect a Delonghi Super Penguino split system portable air conditioner exterior unit?
Time for a service call. You just released some of the freon in your system and now it's not charged correctly. Thank god nobody got poisoned. Have the tech reclaim the refrigerant you have left and disconnect the hard lines and electricity. Do your project, then call the tech back to connect, recharge and test your unit. These things are not cheap. Welcome to the world of home repair. Please find my answer helpful, and good luck with your project. 25352024-u40lsvyytnuesyuv3fbafhtd-5-0.jpg
Jan 03, 2015 | DeLonghi Heating & Cooling
How do you shut off airconditioning pipes?
How do you shut off airconditioning pipes? to keep gas in unit when moving to different location.
Mar 15, 2013 | Cfm Daikin R410a Split System Air...
How should I disconnect outside unit pipes from inside unit "IAQT32C2bedhac" air conditioner without losing liquide/gas?
Hello, if this is a split system AC then you can pump down the refrigerant into the condenser. You would need a set of gauges to do this. It would involve checking the pressures and closing off the liquid line and suction line, this will keep the refrigerant in the condenser and allow you to disconnect the line set.
Oct 06, 2011 | Heating & Cooling
How to install split type aircon?
Plan the location of your outdoor and indoor unit. Make openings for the pipes and wiring's that should be accessible for repairs or maintenance. Never place the condenser near the walls, and follow the allowable clearance from the walls. Same thing follows for the indoor unit make allowance from the ceiling and it should be tilted to drain the water from the drain pan. Make the piping and wiring connection following the suppliers recommendations. Drain pipe should be lower than the wiring installation. Do not use seal tape for threaded connection, only apply refrigerant oil and tighten all nuts. Leak test or vacuum the lines from the valve fittings outside the condenser to the evaporator( in and out of the evaporator ). If vacuum or pressure stays unchanged for an hour, there is no leakage. If you applied vacuum, just fully open the service valves. If you pressure test the line with Nitrogen, release Nitrogen gas by loosening a little the bigger pipe nut from the condenser until no pressure comes out.Then open the small service valve from the condenser a little until pure freon comes out of the loosen big nut and then tighten it. Full open all service valves and unit is now available for operation with power supply.
Sep 03, 2011 | Friedrich (5TF37) Split System Air...
Do split air condition need good ventilation
Well if your asking that if it needs a good ventilation? Yes.
Some things to consider when moving the compressor unit.
1. Length of the tube to be added ( for coolant).
2. Maintenance space.
3. Ventilation
4. Some liquid to be taken care of or gas.
5. Drain water.
For additional inputs. Aircon basic set up is exchanger. On the other side it collects hot air then flush it on the other side which is the condenser that is using fan to flush add added temperature.
Sep 17, 2009 | Heating & Cooling
Hi we have a ge air/cond split system which i want to move to another position i know the system does have an accumulator in the main unit i just wanted to know how to reclaim the gas back into the...
need gauges attatched to the low side (Fat pipe)at the condenser unit which is outside.Use the allan key and close off the high side(small pipe ) at the condensing unit. With the unit running watch the gauges untill needle reaches 0. Quickly close valve off on fat pipe and then switch off. You can then dissmantle and relocate unit. Note, before opening valves again, you must pull a vacume to remove moisture otherwise you will have no end of problems.
Sep 14, 2009 | GE Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Blueway air conditioner not fully cooling
Check the radiator for dirt, and check if the radiator fan is functioning. Do you notice any wetness or ice build up on the outside copper pipes. If so, suggest calling a refrig. tech. to add gas. The gas used is R22 on most aircons.
Feb 02, 2009 | Heating & Cooling
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
I recently obtained a PAC S1000 split airconditioner. I is an older model, perhaps 2005/2006 I have no operating manual for this unit. However having looked at this model on the Internet, it looks slightly...
They will have to be cut and brazed.
Regular solder will not hold.
High temp brazing is required.
Also, it is illegal to cut into a refridgerant system without first recovering the refridgerant. It is also illegal to tap into refridgerant systems without having an EPA certification. It can result in very hefty fines.
I know thats probably not the answer you were hoping for. Howver, I would be neglecting my duties to not inform you of it.
Again, to directly answer your question.
If there are no disconnects on the refridgerant lines, they would have to be cut, and rebrazed.
This requires recoveery of refridgerant, vacume of the system, and an EPA certification.
Jan 10, 2009 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
