Question about Harman Kardon SoundSticks Computer Speakers
No sound from sound sticks ... they're almost new
'Just had a new hard drive put in my iMac. I' reloading all of the previous programs on the old drive and when  I went to connect my sound sticks: they don't show up as a audio output option in systems preferences ... which it did when I first hooked up the sound sticks.
Is there a missing driver to download? or equal or what !?
Stumped.
  • Solavei Mar 16, 2009
    I have sounds sticks from a few years ago... this macbook pro is newer and the sounds sticks are not recognized... am I just missing a driver?
Never mind... I found the USB Output in the "sound" icon on my control panel... one click and sound came a blazin'
Posted on Mar 16, 2009
Windows 10 transfer
Use a software program such as Acronis to completely backup your existing hard drive while it is working. Then when it dies you use the same program to install the backup you made to the new hard drive.
The program will put the backup on your external hard drive and use it in the future when the time comes to reload your new drive. The programs installs usb drivers so you will have no hassle using the external drive to reload the new drive.
That program has saved my sorry rear beaucoup times!!!!!!!!
Jul 23, 2016 | Computers & Internet
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
How to fix canon printer MX 432 that says no pages found?
did you reload the program on to the new computer and if you have then it cald be that the printer has a fault in it from the storm and the best thing to do is to buy a new one
Jun 17, 2013 | Office Equipment & Supplies
TRYED TO PUT IN NEW CASE BUT PUT BACK IN OLD ONE NOW IT WONT LOAD UP I JUST GET IT BLEEPING ALL THE TIME IT COMMING UP WITH NO SIGNAL ON THE SCREEN NOT SURE IF WIRING RIGHT ON USB HEADER CAN YOU TELL THE...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 04, 2011 | Intel Computers & Internet
SD card will not import in to iPhoto '09 using c5280 printer
I dont work with Mac's but it sounds like the new Imac isnt syncing with the iphoto, if you have a syncing program , please run it and then try again, sound like a mismatch.
Jul 14, 2009 | Apple iMac All-in-one - 2.66GHz Intel Core...
The program will not tack my password
Probably it doesn't recognize the hard drive, you might have to reinstall the program from scratch on the new hdd.
Jan 12, 2009 | 321studios 321 Studios DVD X Copy (Backup,...
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
I can't repair bad sector in my harddrive?
You should immediately buy another hard drive. Reload the new one with your OS, programs, drivers. Cable Select them with the new one as master and old as slave. Transfer your data files to the new hard drive. Do this before it's too late and the drive crashes completely. It's only a matter of time.
Nov 21, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Harman Kardon SoundSticks Computer Speakers Logo
381 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
