Question about Frigidaire GLTF1670A Front Load Washer
Broken shock and drum/seal leak
Front load washer, right shock broken and leaking from drum How do i replsce the shock (looks a little tricky so any tips would help)? Should I replace both? Lesks from the drum - a seal because shaking from broken shock or need to tighten screws? Can I fix it easy or??
  • Anonymous Mar 25, 2014
    Drum doesn't rotate unless screw is tightened
    President:
  • 1,294 Answers
Power off the wall mains. Open up the machine panel to look interiors. See if any springs or shocks (known as dampers) have broken or come off. The dampers should not slide in & out freely, if they're defective, replace. Tighten all loose wires, which may have come loose, future probs, so you dont have to open up again.
Next level your machine, front legs way up, means your machine is tilting towards you. Then adjust accordingly so that u cannot shake the machine with both your hands. Lock the nuts, only the fronts legs are adjustable, for most machines. (will get back to u)
Posted on Mar 20, 2009
  • prem mathew Mar 20, 2009
    Re. the drum leaks you should locate where it comes from; the door seal is replacable, all by yourself. For the shocks you need a set of spanners, replace only the defective shocks (dampers). Note how the nut washers, etc are placed & do likewise for refixing the dampers, no problem there. (& dont forget to rate me nice)
    Sites for spares:
    RepairClinic.com
    espares.co.uk
    AppliancePartsPros.com
Can water be held in drum or under drum... my water is off but its still dripping underneath.. for 2 days now also can overloading cause this to happen?
The design of this washer has the tub (outer container) in two half's that clip/bolt together. It is likely that the seal that seals the two half's has failed. You need to confirm that this is the source of the leak. Others have reported as you the same condition and have confirmed that this seal will leak.
The red arrow points to part number 10 seal.
It you can confirm by observing the source of the leak that it is the seal the part is available and this can be repaired!! The repair is not for the faint of heart and requires lots of experience and finesse.
If you cannot confirm that the tub seal is leaking then check the front door seal. The front door seal is not as difficult to replace and there are many videos showing the replacement. Your observation that the leak continues is an indication that the residual water in the tub is slowly leaking. If the washer has frozen then it is possible that it might have been related to the leak. I expect that the load size is not the root cause.
Check you owners warrantee this leak may be covered by an extended manufactures warrantee.
You might live with the situation for a little while finding a tray to catch the water. Others have reported mold forming on the tub.
If you are not strong of heart to tackle DIY, but fat in wallet you may seek to get a repair estimate. Compare the repair cost with a replacement machine.
26039797-cmpppu1nchs2wy552ovfnv1h-5-0.jpg The following video makes the replacement seem so easy!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
Jan 05, 2016 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Avanti w1092f front load washer leaking water from the botton
Look under and around the door and drum seals for debris. Had a coin in the seal once, took it out leak stopped.
Nov 27, 2011 | Avanti W1092F Front Load Washer
I have a Hotpint Aquarius Washer/Dryer model number WDL520 that seems to have sprang a leak. First it was water only trickling from under the botton left hand side at the front. Now it gushes. Any ideas...
you could have a broken pipe on the filler or the seal has gone on the drum you would need to have a look, either way they are easy to fix or replace. drain pipe can leak if the pipe has come off the pump also check this but you will need to remove the case to get to look, always unplug the washer before touching any screws, remove case and look at the pipes and make sure they are seated in the right place.
Sep 09, 2017 | Hotpoint Aquarius WD640 Front Load...
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Front seal not supporting drum, drum flops violently, doesn,t leak. seal wont stay on drum.
it sounds like you may have tub bearing issues or your suspension springs or shocks may be missing or broken. The front seal is just there for sealing, thats its sole purpose.
Basically there is two parts, the inner stainless steel drum and the outer plastic tub housing. Reach inside and see if you can move the inner stainless drum up and down any significant amount? If so the bearings are most likely shot. If its pretty solid but the outer plastic tub moves, its most likely a suspension issue. You can take off the top to get a much better view of the components.
Oct 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer leaks during spin cycle. my daughter pulled the drum out of alignment temporarily while pulling a comforter out of the washer. the door seal is intact although there is a wire ring that came out...
The spring goes around the door seal it needs to be stretched around the small lip that holds the seal in place. The spring is where you grab it with needle nose pliers. the spring goes on the bottom. You will see where the rubber seal has a wider spot this is where the spring should be right at the 6 o'clock position. This is a little tricky to do the first time trying but keep at it you will get it.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG Top Load Washer
this could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Jul 17, 2008 | LG WFT1071TP Top Load Washer
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Frigidaire GLTF1670A Front Load Washer Logo
481 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
