Question about Whirlpool LER4634J Electric Dryer
Need to open the bottom part below the door, ideas how to get in there??
  • 135 Answers
Unplug. Remove 2 screws @ lint filter. Pull forward on top one side at a time and lift up each front corner - entire top will hinge upward. Remove switch wires at front and 2 5/16 screws. Pull front up and out. Hope this helps!
Posted on Mar 09, 2009
Electrolux washer EIFLW50LJWO door will not open how do you open it when it will not open
Some front load washers have a pull tab on the door switch. To access it you either have to remove the top panel and reach down to the door switch from there or some have a bottom access panel across the bottom front below the door to remove and you need to reach up to the door switch. Please remove power plug first. Tab is usually a small round tab you will either pull up on or down on depending where the tab is located.
Mar 07, 2015 | Electrolux Washing Machines
How do you get the battery door open on the sharper image u-video camera?
The battery door is at the bottom of the camera, just below the little box with THE SHARPER IMAGE in it and opens easily ...if you know the trick. (The tripod mount is in the bottom of the door.) using your thumb, press down on the tripod screw hole and push on the door from the front of the camera toward the rear and the door pops open. Reverse the procedure to close.
Dec 25, 2010 | Cameras
My Zanussi DS17 slimline dishwasher is leaking from below the door at the front. The inside seals all seem to be fine, but the catchment moulding below the door (which is revealed at the front when the...
Have a look at the bottom spray arm and check the ends of the arm for splitting as this will cause the water to be directed at the door lower section and leak.Try taking arm out and run for a short while and see if it stops the leak.If still no good check that door is closing fully.
Apr 25, 2010 | Dishwashers
Need to reprogram sears garage door remote opener
Click below to get to the manual you need. Just scroll through till you get to your model number.
http://www.managemyhome.com/mmh/owner_manuals/search?query=GARAGE+DOOR+OPENERS&find=
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
How do we adjust an aluminium door?
the door has a cam that has to be adjusted to force the pin up
call a local glass company and ask them where the adjustment is located
there is usually some type of access plat near the bottom of the door frame close to the hingee on the inside close to the bottom
Nov 26, 2008 | Locks & Locksmithing
Bosch maxx wtl 6300 dryer when placed on a dry cycle it beeps every couple of minutes and stops and the filter light flashes. The lint filter is cleaned and it still does this any help?
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
May 14, 2008 | Dryers
How to open door
you push the button that has a picture of a key. if that doesnt work, there is soemthing wrong and you need to call a servicer
Sep 20, 2007 | Washing Machines
Thermador 6 Burner cook top
It sounds as though you have soem nice, well sealed cabinets and a good installation on your cooktop. When you open the drawer. it creates a momentary vacuum that sucks the oxygen away from the cooktop, as the bottom of these are not airtight. The only thing you can do is to open the drawer more slowly or have a vent of some sort installed in the back of the cabinet to let air in as you open the drawers, so it does not suck it from the top.There really isnt anythig wrong per say, it something that happens with most gas cooktops with drawers/ doors below them. Hope this is helpful.
Dec 27, 2006 | Thermador SMW272 Electric Double Oven
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
