Question about Sun Ultra 10 PC Desktop
I have an ultra 10
My monitor is always flashing different colors & I have a hanns-g monitor I try turnig it off & turning it back on & the same problem goes on but my dad fixed it, Oliver Fyffe
  • Dominic
    Dominic May 11, 2010
    Usually that is a sign of a loose connection cable or bent pin.
    Are you running Solaris?
    Is the connector DVI or SVGA?
  • 114 Answers
If your flashing differetn colors its your connection
Posted on Mar 09, 2009
Im having issues with the hanns-g hg281d. my screen is always faintly flickering, especially when the screen is on darker colors
i was having same issue.i would turn off monitor for 10 secs. then turn on .and it would not happen for a while .i went to i cable and it now rearly ever happens.
i use this as a external monitor for my laptop for 6 mons.now.
Jan 04, 2011 | Hannspree HW191D LCD Monitor
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Flashing green LED on my Hanns-G HX191D
Common problems on monitors are due to capacitors in the power supply/inverter circuits failed, you need to open it up and look inside for caps with bulging top/seal first and post back what you see so we can guide you further, see failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 17, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Black screen green lite on/flash right green lite off
The problem on your monitor is a bad power supply. We you can solder you should be able to repair it. If you check our site at :
www.ccl-la.com/badcaps.htm We have a monitor repair section with dis-assembly guides and repair procedures. I will post a Hanns-g guide tonight. This will show how to open and repair the monitor. We also have a repair parts kit available. If you don't want to do the repair yourself then we can do it for you, just email me if you have questions or wan tus to do the repair for ou.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Aug 05, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Monitor flashes 7 or 8 separate colors
Your monitor's inverter board is a toast you will have to replace it.. Post back if you have experience in electronics and you wanna try it yourself..
Mar 26, 2008 | Liquid Video A170E101 Monitor
Monitor problem
Hi, I used to repair a monitor from Dell. You might have to check what wrong with your monitor when it went back by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem like broken lamps and it is very easy to replace. But the most important part is you need to know how to teardown the screen. . If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Hope this help you to examine your monitor. If there is anything I can help you with, feel free to let me know.
Thank you,
Mar 12, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Sun Ultra 10 PC Desktop Logo
108 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
