Question about Nintendo Wii Console
How do i get connection 24 on my wii?
On my nintendo wii,when i try to set up wii connection 24 it comes up with an error code.The error code is either 51420 or 51421. HOW do we get connection 24?
  • 21 Answers
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Posted on Apr 07, 2009
    Genius:
  • 1,234 Answers
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
_____________________________
Error Code: 51421 The Wii console is not able to connect to your wired router or modem.
Posted on Aug 26, 2010
4 Suggested Answers
shizmo
  • 94 Answers
SOURCE: error code 109144 when try to connect to internet via wii console
Error Code: 109144 There was a problem registering the console to the WiiConnect24 service. What to do:
  • If you have multiple routers and/or modems, try to connect to no more than one router and one modem try connecting from another location.
  • If you are using only one modem or router, something on your network or from your Internet Service Provider is blocking the connection. You may need to contact your service provider for more information.
  • If you do not have the ability to connect from another location (such as a friend's house), please call 1-800-255-3700 so that we may discuss available options.
Posted on Feb 01, 2009
  • 23 Answers
SOURCE: Okay, in the Nintendo Wii I go to the Wii Shop
Try changing your channel on the router to 11 or 1. For Linksys WRT54G routers enter the ip address of the router (default is 192.168.1.1) enter password and user name (default is admin/admin) then click wireless tab, now select a different wireless channel from the drop down box. Fix is not guaranteed to work for all consoles. source
I was having a big problem with those two errors, when I realized that the WEP encryption has to be set on Key 1 in order for the Wii to recognize it. It\'s the same with the DS.
I would like to add to the information you have posted that on top of what you have posted, I had to change the MTU value from 0 (Default) to 1500 witch it was in the router for the Wii to finally connect and download the updates. (via email, thanks Jose
Solution 2:
The console of my girlfriend had this error code and none of your solutions could help, but I found another one: I had to put in the IP manually because the Router's DHCP-Server didn't work.
Solution 3:
I originally received the 52030 error code, followed the directions from this site but could only get MTU to 1492 (Linksys 802.11B router, too lazy to look up the number).
Connected for about 5 minutes, was downloading the update, got to 100% then gave me the same error code. Went back in, recreated the connection, worked, went to download update, this time it got to 60% and just stopped. My ISP was fine but the download simply wouldn\'t progress. Hardbooted the Wii, reset the internet connection and nothing. Tried multiple times with same result, Error Code 52230.
Had been having other problems with my router so I figured that was the source, headed over to Wal-Mart (yippy!), picked up a Linksys 802.11G router, plugged in and everything worked without a hitch.
Moral of this story...buy a new router and plead to your significant other, But honey, look how cool the Wii-Weather Channel is! later. TOTALLY worth it.
Solution 4:
I love my Wii. The only thing I hated initially was the network setup. I kept getting the error code 52030. I have a DLink 624 router (hardware reversion C). I fixed my Wii connection problem by upgrading my firmware to 2.76 and setting the wireless router setting to SuperG without Turbo on Channel 11.
Posted on Jun 29, 2009
  • 47 Answers
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
Posted on Jan 27, 2010
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit cbrtechsolutions
Mar 27, 2012 | Belkin Surf N300 Wireless N Router
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Why is 51030 coming up why im trying to get on the internet on my wii.
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 29, 2011 | Nintendo Wii Console
How do I get my Wii to connect to my internet wirelessly? When I try I get error code 51331
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51331 is:
Error Code: 51331
This error code is more specific to having incorrect security settings on your wii. Your encryption key is wrong when trying to connect to your wireless internet. Double check your encryption key with your router's settings and try again.
You can see the official support article from Nintendo here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=lang
Apr 27, 2011 | Nintendo Video Game Consoles & Games
Error code 32032 (wii)
Jan 23, 2010 | Nintendo Wii Console
Wii console says wii connect 24 is off. how do I
To Access the WiiConnect24 setting:
  1. Access the Wii System Settings
  2. Move the cursor over the blue arrow on the right and and select it once to reach System Settings 2.
  3. Choose "WiiConnect24.
Dec 19, 2009 | Nintendo Wii Console
Wii will not update, comes up with and error code message
Error Code: 32002 The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later.
If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review the folliwing information:
  • Ensure you have entered the correct DNS into the Wii console's manual settings (link). You can verify this by following these steps:
    1. Click the "Start" button in the lower left-hand corner of your computer.
    2. Click "Run."
    3. Type "cmd" into the box and press Enter.
    4. Type "IPCONFIG/ALL" and press Enter.
    5. The Subnet Mask, Default Gateway, Primary DNS (first listed), and Secondary DNS (second listed) information will be displayed. Ensure the information you have entered into the Wii console's Manual Settings appear exactly as displayed.
    6. If you have more than one DNS server listed, try switching the first and second in the Wii's primary and secondary DNS server slots.
  • Try temporarily disabling your router's firewall. *
  • If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
    Wii LAN Adapter
If you have tried the steps above but are still having issues connecting, it's possible that our servers may be temporarily down. Please try your connection again later.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
Sep 25, 2009 | Nintendo Wii Console
My wii connect 24 won't connect to the internet and it say error code: 51330.
It's a problem with your internet connection. It could be as simple as mis-typing on of the settings, i.e. the SSID. Otherwise try changing this channel your router broadcasts on to 1 or 11. It worked for me. Check out http://www.nintendo.com/consumer/routers/en_na/routerIndex.jsp for more details about your router. Or http://www.wiierrorcodes.com/wii-error-51300-51399.php for more details on the error number.
Jul 18, 2008 | Nintendo Wii Console
The wii is unable to connect to internet
It seems that it can't establish communication to your access point.
Nintendo Forum explanation:
Wii Error Code Group: 52020, 52021, 52022
Summary: Connection difficulty with either router or modem.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
Consult the Nintendo Forums for detailed help.
Jun 12, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
721 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
