Question about Kenmore 62602 Electric Dryer
Dryer flips the breaker ran 4 1 year and nothing changed started this 2 days ago any idea about the
  • 5 Answers
If its tripping your breaker either the motor is seized for some reason (easily tested by trying to turn the motor pulley by hand), or something in it is shorted out, most likely thing to short out and trip a house breaker is the heating element.
You can easily test the heating element as the possible cause by taking the 2 wires off the element connector, tape up these wires so it doesn't short out, plug the dryer in and try to run it. If its the heating element shorted out then the dryer will now run without tripping your breaker but of course not heat. If so replace the element.
Posted on Mar 11, 2009
Maytag MED5700TQ Electric Dryer lost all power
Hopefully you still have your manual-if not dwn load this one and go to page 23
Download 20W10150608A.pdf initiated. If download did not start, click here to try again.
Dec 29, 2012 | Maytag MED5700TQ Electric Dryer
When I press the start button on my dryer it does not come on, and does not do anything at all not even a sound.. This dryer I bought brand new, and it isn't even a year old yet??? Any Ideas as to
Hi, have you checked the breaker? It would be a 220 breaker meaning a double handle or heavy duty one in your breaker box. look for one that is slightly out of line or has a small red dash showing..flip it back and forth to re-set.
Jan 08, 2012 | Dryers
One of the 2 breakers for dryer flipped off,
This is a strange situation.
I would normally expect a electric dryer to rujn on 220 volts which would be provided through a tandem breaker, When one flips off, the other must flip off, they are fastened to gether.
I would expect a gas dryer to operate on 110 volts and the poser to come throlugh one breaker. The motor would run but that is not to say the gas will burn to make the heat.
I suppose yoj could have a 220 Volt Gas drier, but there would be little benefit based on the added expense of the motor.
If you are certain you have two breakers for your dryer, it might be time to have a electrician take a look-see
Thanks for posting your question at
Dec 14, 2009 | Washing Machines
Kenmore Model 110 washer humming/popping breaker
Good day,
Anytime an appliance knocks a breaker down, the motor is the obvious culpret.
The first thing to do is remove the motor and take it to an appliance parts house for testing.
If the coupling broke, it is just sometimes just happenstance. In other cases it could be a transmission starting to lock up, which would overtax the motor, and eventually cause it to fail.
Lastley, most models are 2 or three speed. If the timer screws up and tries to run the motor on high and medium or low at the same time it will fry the motor.
Dec 10, 2009 | Kenmore Washing Machines
One of 2 circut resets keeps tripping on our Generac generator
If it's tripping a breaker that usually means there is to high of an amp draw on that curcuit.
Are you plugging more things into that particular curciut (or just different but higher amp draw items) than you did last year?
It's also possible that one of the items plugged into that curcuit is wearing out and drawing more amps than before.
If you have an amp meter, plug everything back up just the way it was when you were having problems. Check the main wire going to that curcuit. (right at the breaker)
If your amp draw is greater or nearly the same as the amprating of that particular circuit, then thats your problem.
To many things/to high amp draw on one circuit.
If it is not near the amp rating, and you are getting proper voltage to the breaker, then I would replace that breaker.
Dec 30, 2008 | Electrical Supplies
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Dryer won't turn on
the heater element on the drier has gone short circuit.without a model no. its impossible to give more me on dazzie@blueyonder for more assistance.
Dec 29, 2007 | Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Child Lock continuously flashing
the solution is to change the electronic control.....cost 110$
Sep 02, 2006 | KitchenAid 24 in. KUDS25SH Built-in...
Kenmore 62602 Electric Dryer Logo
142 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
