Question about Samsung Weather Resistant Security Camera SSC-12C
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
  • CESAR  QUANT
    CESAR QUANT Mar 09, 2009
    but the rj11e has 3 pairs of wires i know that 2 are for video , 2 for power and 2 for audio
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Posted on Oct 30, 2014
  • 423 Answers
Well, your going to need RJ45.
RJ11 is telephony and has 2 pairs of wires. With that, you could use the Blue/Blue-White for power and the Orange/Orange-White for video. Then your stuck.
RJ45 has 4 twisted pairs.
To find out which has power, use a meter to measure your 24 volts.
Rob
Posted on Mar 09, 2009
  • 2 more comments
  • Rob
    Rob Mar 09, 2009
    Also, you also know your going to need a tranceiver right. Just checking.
  • Rob
    Rob Mar 09, 2009
    Ok, sorry, I misread your post. Are you talking about at the camera end, or the receiving end? Are you coming back from the camer into a punchdown board?
  • Rob
    Rob Mar 10, 2009
    Hi Cesar,
    The only way your going to know which pair of wires is going to run power is for either to use a balen to convert the connector to BNC. If you plug your rj11e directly into the camera, which you probably do, then the ONLY way to know is to get a schematic from the camera manufacturer. It's easy to get the pinout for that cable off the web, but you still won't know for sure which pair the camera is going to use for power, video, and audio.
    Again. Call or email the manufacturer for camera schematic, so you know for sure.
    Rob
  • tim coffey Dec 17, 2010
    i just spliced the rj11 to the cable that came with the dvr the pinout on the rj11 is
    back of camera clip up contacts down
    1-speaker ( )
    2-video out
    3-gnd
    4-speakers (-)
    5-audio out/ alarm out
    6-12vdc
    it worked fine
Hello\r\nI have a kc-2a camera and would like to know what the pinout is? hope you can help thank you K.V
Its RJ11E. If your system doesn't support RJ11E, you can find a adapter at B&H (that's where I got mien) to connect to a BNC DVR. Make sure the camera has the right Power supply. KC-2A use 15V dc... most camera's I have use 12V.
Aug 11, 2011 | Ultrak Kc552bcn Ccd Cctv Color Security...
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
Need wiring map for RJ11 conector for Samsung SOD-14C camera
Well good news and bad news if u just got shot ends easy cut end off and copy other end with new rj11 6 pin phone jack.. what im trying to do is give camera secondary 12v power and use the wire in the jack to splice into RCA type connector to work with my old dvr
Sep 12, 2009 | Samsung Color Fixed Security Camera...
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Jan 20, 2009 | Samsung Color Fixed Security Camera...
I bought a CCTV system for a school but I have some electric problem that the image looks like it's flashing? what is the problem since Iam new to this. IT's like it has brightness
Line loss from the camera to the DVR or monitor and ground loops are the most common problems. If you only see black and white from a color camera, it typically means the cable from the camera to the DVR is too long and/or has high loss caused by a poor BNC connector.
Excessive brightness can mean the video signal from the camera is too strong. This can be caused by an impedance mismatch from using the wrong type of video coax (cabling).
Additionally, a camera power supply plugged into a different electrical circuit (not the same outlet as the DVR or montior) can cause ground loop problems that can affect the video quality.
Dec 14, 2008 | Samsung Color Fixed Security Camera...
SCC-343P Security camera cant get video out
I would check the iris on the camera, if it's all the way open, then it's probably not the fault of the camera. What are you using to view the image?
Rob
Oct 14, 2008 | Home Security
I have two samsung ssc-12c cameras.
green wire : 12v dc
clear wire : video ( + )
wire around clear wire : video and 12 vlt ground ( - )
you don't used the rest of wires . rest are audio .
Nov 20, 2007 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
3,844 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Mike
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
