Question about GE JVM2050 Microwave Oven
My G E microwave model #jnm1541sn1ss won't heat is there a fuse I can replace. Or something a pro needs to do?
Everything on this unit works but the heating process!
SOURCE:
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
djicenova
  • 319 Answers
SOURCE: Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Posted on Mar 21, 2009
  • 8404 Answers
SOURCE: Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Posted on Oct 19, 2009
Testimonial: "Fixed it. There is a fuse in the front top right corner. Three screws and one 250V 20 Amp fuse later, Works.. Wife called repair center wanted $47 "
heatman101
  • 43501 Answers
SOURCE: Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Posted on Feb 25, 2011
heatman101
  • 43501 Answers
SOURCE: kenmore microwave model 721.80033700 won't heat
heatman101
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
No heating, still cold
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Jun 28, 2011 | Oster OGB61101 Microwave Oven
Microwave does not heat
heatman101
Jun 15, 2010 | Whirlpool MH7140XF Microwave Oven
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
GE JVM2050 Microwave Oven Logo
71 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
