Question about Nikon N75 with 28-105 lens 35mm Film Camera
I can't get meter reading for my Nikon N75
Does anyone know if the TTL meter for Nikon N75 work when set to manual? Mine does not appear to be functioning. Thanks.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
It depends on the lens. If it's a CPU lens (has electrical contacts) then the meter should work in any mode. If the lens doesn't have contacts then the meter won't work.
Posted on Dec 23, 2009
I would like to know if a 24mm Nikon f2.8 Ai Manual Focus Lens will work on a Nikon N75 SLR Camera
Yes and no. It will fit and you can take pictures with it. You'll have to focus manually, of course, and you won't get any exposure help from the camera's light meter. You'll have to use the camera in the Manual exposure mode, setting the shutter speed on the camera body and the aperture by turning the ring on the lens and, as I said earlier, without any help from the camera's light meter.
Mar 17, 2012 | Nikon N75 35mm SLR Camera
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
Need a manual for a nikon n75 camera
Hi
RIGHT CLICK ON LINK BELOW, CHOOSE "SAVE TARGET AS"
SAVE TO FOLDER OF YOUR CHOICE (Adobe 5.0 or above needed to read it)
Click here to download First part of PDF Manual(Nikon N75 )
Second part here ...Third part here
Mar 23, 2011 | Nikon Cameras
I have a Nikon Speedlight SB-800. Before I take a picture from my Nikon D70 the flash will click about four times while there are spurts of light coming out of the bulb then the picture will take. Never...
The pre=flashes are for reduction of red eye and also for TTL indormation for camera to wotk properly with flash. Read Flash manual and some info in camera manual
Jan 10, 2011 | Nikon Speedlight SB-800 TTL Flash
Why does my sb-800 doesn't show the meter and ft. and doesn't have a guide GN menu?
Since SB-800 is a dedicated TTL flash, it doesn't need you to manually set the values. The flash can communicate with the Nikon cameras automatically in TTL mode.
Sep 22, 2010 | Nikon Speedlight SB-800 TTL Flash
Will the Quanta 28-200 for the Nikon n75 work on the Nikon D5000?
Yes and no. I assume the lens is of more or less the same vintage as the N75? If so, the lens will fit onto the D5000. All of the camera's exposure and metering modes will work properly. However the lens lacks an interal focus motor and thus will not autofocus on the D5000. You can focus manually, and the green focus indicator in the viewfinder will continue to work.
Apr 22, 2010 | Quantaray 28-200mm f/3.8-5.6 for Canon AF
Nikon SB-800 TTL settings for Nikon D40X required
No settings - the SB800 is automatic on the D40x - it meters TTL.
May 11, 2009 | Nikon Speedlight SB-800 TTL Flash
Use of Nikon SB22s as slave flash.
in the manual setting the SB-22s is just a standard flash and should work with a standard hotshoe.
Dec 18, 2008 | Nikon Speedlight SB-22S TTL Flash
My Nikon N75 has F-- on the digital screen
Set the smallest aperture (largest Fnumber) and lock the ring. If the aperture ring doesn't have a lock, you have to switch to manual mode (M on the mode dial).
Sep 16, 2008 | Nikon N75 35mm SLR Camera
Can I make the Vivitar 6000AF for Canon work on a Nikon DSLR?
As a manual flash, yes. Just cover the other proprietary pins and leave the centre trigger pin.
As a TTL flash, no. Canon and Nikon uses different hotshoe and flash metering.
For non-digital TTL, I would think Vivitar 6000AF is good?
A more appropriate similar product for DSLR is Suntax DRF14
http://www.suntax.com.sg/DRF14.html
Jan 27, 2008 | Vivitar 6000AF for Canon TTL Ring Light...
Nikon N75 with 28-105 lens 35mm Film Camera Logo
101 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
