Question about Kenmore Oasis HE 27082 Top Load Washer
I took off my rear cover of my kenmore washing machine. I found the leak and replaced the water pump. there are 2 large clips that held the back panel on and I don't know how to reattach it.
  • landsend
    landsend Mar 13, 2009
    I HAD THE SAME PROBLEM AND ENDED UP DRILLING HOLES AND PUTTING 3 SCREWS IN.
  • 15,935 Answers
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
NOTE: Under Line Item 10. - after you remove the motor mounting plate, make sure you disconnect the wiring harness from the the gearcase housing if it is mounted to it. Otherwise, you may damage the harness when you remove the gearcase assembly. Make sure you re-install the wiring harness in the fashion when repairs are completed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
Water leaking. A small amount of water leaks when
The usual cause of such leak is a damaged or worn drain pump. Replace it to solve the problem. It can be accessed from the back if it is a belt drive machine or from the front if it is a direct drive. Make sure to unplug the machine before servicing.
Cabinet Removal Procedure (Direct Drive machines)
Remove the console depending on the model of your machine.
  1. If the console is secured by screws, simply remove the screws, lift the console up then flip it to the back of the machine. On some models, the screws are hidden under the console's removable end caps. Pull the end caps to the front of the machine to access the screws. If the console is not held by screws, use a putty knife to release the retaining clips under the front corners of the console. Insert the putty knife blade and push it until the clips are released.
  2. Disconnect the lid switch connector from the body of the machine.
  3. The body of the machine is held on to the back panel by two retaining clips. Use a flat blade screw driver and insert it to the lip of the clip and push it to the back of the machine.
  4. Lift the lid and grab the front of the machine's body. Brace the machine's body with your knee, lift and pull it towards you to remove it. You now have the access to the drain pump.
  5. Reinstall the cabinet in reverse order of the procedure above.
For belt drive washers, remove the access panel on the back of the machine to access the drain pump.
Drain Pump Replacement Procedure
  1. Remove the spring clamps that hold the hoses to the pump. Compress the spring clamps and move it away from the pump.
  2. The pump is held on to the motor by two retaining clips. Pry the clips away to remove the pump from the motor.
  3. Remove the hoses from the pump and install the new pump in reverse order of the procedure above.
Jan 20, 2010 | Kenmore 15864/15862 Top Load Washer
Water pump leak how to remove to change seal or crack from freezing
Remove two screws at the front bottom ends of the control panel and tilt it back to expose two large brass color clips that hold the cabinet in place. Disconnect the lid switch wiring at the plug. Remove the clips and lift/slide the cabinet forward to remove it. The water pump is at the bottom of the "motor stack" and slips onto the motor shaft. You should be able to see water drip marks from the shaft bearing if the pump is leaking. Remove the inlet and outlet hoses before trying to remove the pump. The pump is held in place by two spring clips.
Jan 18, 2010 | Kenmore Washing Machines
My Kenmore 80 series topload machine is leaking water
This machine has a direct drive pump, in all likelyhood the pump is leaking...unplug machine...pull it out...tip machine on its back so you can access the bottom, if it is the pump there should be water around where the pump connects to the motor, if it is the pump it is a simple process of releasing 2 clips and taking the inlet and outlet pipes off the pump..install new pump the way you took old one off. you can obtain the part from www.repairclinic.com If you would like to give me more details on your dryer i may be able to work out what is wrong with it.
Jun 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Apr 17, 2009 | Kenmore Washing Machines
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 70 series
The following link explains how to replace a pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
The pump is only held in place by two retaining clips. Once the clips are removed, the pump (with hoses still attached) pulls directly off the motor shaft. NOTE: If the pump is leaking, it is NOT repairable and requires replacement. These pumps are sealed units. Replacements can be ordered on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offere competitive pricing so shop all three for the best price. If you require addtional assistance, please let me know. I hope this helps you.
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Washing machine leakes some where frome the bottom of washer
It sounds like you pump is leaking. This happens most of the time( if its a kenmore or whilpool)lean your washer back and then you will see the pump on the end of the motor. it is held on by 2 clips and then you can take it off (after pulling iff the 2 water hoses) Look at where the motor shaft goes onto the pump if its leaking there will be a water streak. Replace the pump... leak is fixed
Oct 28, 2008 | Kenmore 23822 Top Load Washer
Kenmore washer 80Series water leak
First of all, you never want to tip this machine over, it can cause oil to leak from the transmission. The best way to locate the leak is to fill and run the machine with the cabinet removed. Begin by removing the two trim caps on either end of the control panel, they clip on, and should pop off by hand or a slight pry with a flat screwdriver. Then, remove the two screws securing the panel to the cabinet and flip the panel up. There should be two clips securing the cabinet to the frame (gold colored). Pop out these clips with a screwdriver for leverage. Next disconnect the wire harness from the lid switch connector on the cabinet. The cabinet should now be ready to pull off the frame. Plug the machine back in and set it to run a normal cycle, let it fill and agitate, (some models will not agitate without the lid switch being closed, in which case you will need to use a jumper wire). Biggest problem areas are the Pump, water valve, hoses, or possibly the plastic tub itself.
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
90 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
