Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
I need a very small milliners staple gun uses small brass staples
Needed to decorate and finish small doll's hats and clothing. It uses either brass or colored staples and thus far has been impossible to locate. I know that they are available; the doll companies use them. Where and how can one be obtained?
Thank you for any assistance!
Lynn
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
joboo1
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    On a T50, the staple driver (plunger) does not come back far
    you could try it, but i would just buy a new gun they are cheap
    Jul 22, 2010 | Arrow CHROME STAPLE GUN ARROW IND....
    My gun will not shoot staples after loaded I thin there is a part missing
    Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
    Hope it helps!
    May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
    I have an Arrow T-50 which is missing the staple pusher needed to reload. Can it be reloaded without the staple? If not, where can I get that part? Thanks!
    You need the staple loader to keep the tension on the staples. The part is usually not sold separately. Your only chance is to find a used T-50 and cannibalize the part. You can get a new T-50 online for $25.
    Dec 09, 2009 | Arrow T50P ARROW STAPLE GUN
    How do you adjust the staple size to load 1/2" or 1/4" staples?
    Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
    There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
    Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
    Reloading ace 22084 staple gun
    Hello there:
    when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
    best regards michael
    Oct 03, 2009 | Ace Hardware Ace Staple Gun
    Piece of staple stuck in the trigger section of arrow t-50p
    First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
    Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
    Powerfast staple gun works poorly
    Gun is most likely a multi strike gun. Try not moving the body of the stapler and pushing the strike lever again, repeat if necessary.
    Dec 20, 2008 | Watts Brass Pipefast Staple Gun Pipe To...
    Staple gun support
    Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
    Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
    99 people viewed this question
    Top Electric Tools & Hardware - Others Experts
    eddie_brown
    Level 1 Expert
    Jim London
    Jim London
    Mike Carew
    Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
