Question about Welding Tools
I need an assembly diagram for a victor tpr250 inert gas regulator - hoping you can help.
    Problem Solver:
  • 7 Answers
Contact victor direct. They may release a drawing of the assy dia as req'd for industrial admin use.
Posted on Mar 21, 2009
I have an old Victor Mustang do not know the model number .
maybe this video will help...hope so there are some more on other models.
https://www.youtube.com/watch?v=N7AILcgBYyc
Jan 01, 2018 | Washing Machines
Who fixes Victor acetylene valves?
Contact a local welding supply vendor, they should be able to direct you to someone qualified to do the job.
Aug 25, 2014 | Thermadyne Industries 0781-3909 Victor...
Diagram
3767bd75-1262-4a96-bd97-43bbe7f45abb.jpg9cf5b8aa-c349-45d4-b316-e565cabead8c.jpgThe fuel filter is part of the fuel regulator and you replace the regulator/filter assembly. It is located on top of the fuel module itself. You do not need to remove the fuel module in order to remove the regulator and I don't even think the fuel tank itself needs to be dropped although you may have to lower it just a bit to get at it. If you are able to reach up there you can simply remove the gas line attached to the tank, sqeeze the 2 tabs in and pull the fuel line off. The regulator/filter is just a push in that spring tab (see picture) and twist counter clockwise about 90 degrees and pull it out. Hope the pictures help
Jul 05, 2013 | 1998 Dodge Neon
My charbroil masterflame 7000 is leaking gas. I beleive I need to replace the regulator and hose. Please advise on how to get the old hose off and put the new hose on. I need a diagram if possible. I would...
If you have already disconnected the hose from the tank. Track it back to where it connects to the burner(s) manifold. It should be up under the grill head. You should see a brass nut. Using an appropriately sized open end wrench, loosen this nut and the hose will disconnect from the grill.
The new Hose/Regulator Assembly will simply attach in the reverse order of how you removed the faulty one. After installing the new one and connecting the hose to the tank. Open the valve on the tank about halfway and check the connections for leaks. Thick soapy water, brushed on with a paint brush will work for detecting leaks. Look for bubbles other than those made by the soapy water. If you see one, tighten the connection a bit more. Be sure not to cross thread the nut, when installing it.
If you haven't purchase a new one yet, you can the Hose/regulator Assembly at any home center or hardware store that sell gas grills and accessories. They run about $30.00.
Hope this helped you and Happy Grilling.
Jun 19, 2011 | Char-Broil CharBroil Master Flame Gas...
Q-300 plastic tank nut broke, where can I find serial number for replacement
You will need to replace the entire hose/regulator assembly. As the plastic tank connector is not sold as a separate item/part. You can buy a new hose/regulator assembly for about $30.00 at any home center or hardware store that sells gas grills and accessories. Take you old hose/regulator assembly with you for comparison purposes.
Hope this helped you to speed up the replacement part and get you back to grilling.
May 17, 2011 | Weber Q Grill
PRPOANE GAS REGULATOR ASSEMBLY BROKEN. MODEL# 842-0200-0
The model number 842-A250-0 does not match any Brinkmann gas grill models in my data base. However, if yours is a standard gas grill, that uses a 20lb LP tank, you can purchase a hose/regulator assembly at any home center or hardware store that sell gas grills and accessories. Make sure to take you old one with for comparison purposes (ie hose length).
Further, if you regulator has GDA on it. It was recalled by Brinkmann during a voluntary Safety Recall. If your regulator hasGDA on it, contact Brinkmann Customer Service (800) 675-5301 between 8:30 a.m. and 5 p.m. CT Monday through Friday. They will provide you with a free repair kit. You must provide and accurate Model Number & Serial Number of your grill, to take advantage of this Safety Recall.
Hope this helps you find the hose/regulator assembly you need. Please let me know.
May 05, 2011 | Brinkmann 842-A250-0
How to i take off my regulator on my blue ember bbq. FG50069 model clockwise or counter ?
The regulator is part of the Regulator/Hose Assembly. You won't be able to separate the regulator from the hose. You have to remove the whole assembly by turning the coupling connection at the grill head counterclockwise. I assume you won't to replace the regulator. If that's the case, you will have to purchase the whole regulator/hose assembly.They are not expensive and can be found at any home center or hardware store that sells gas grills and accessories. Take your old one with you for comparison.
Hope this helped you and Happy Grilling!!
Apr 21, 2011 | Fiesta Blue Ember Gas Grill
Need parts for victor 272654 oxy reg
I will sell exterior parts only,I do sell internal regulator parts but only to certified technicians that have the test equip and can re-certify the gauges after a re-build
Jul 27, 2010 | Victor Welding Tools
Assembly of lights Smith Victor KT1500u Lighting kit. Help!
How do you assembly the light on the light stand? I have a Smith-Victor Hair light
Jan 28, 2010 | Smith Victor KT1500U Thrifty Iintermediate...
Victor carby diagram
try looking on ebay.com they have alot of manuals on there
Sep 19, 2009 | Garden
Welding Tools Logo
188 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
