Question about Toshiba Satellite A135-S4527 Notebook
Battery stopped charging
When battery stopped charging and went down to zero power, my computer stopped and won't come on even when plugged in.
  • Anonymous Mar 26, 2014
    Hello, The first charging replacement battery stopped due to ext. power lost. now charging stops at 85% only. What should I do to get 100% ?
    Scholar:
  • 54 Answers
Sounds to me like you've got 1 of 3 problems:
1) Your battery is fried and can no longer take or hold a charge.
2) Your adapter is fried or shorted out and is no longer providing a charge to the battery
3) Your power jack on your notebook is faulty and is causing a disruption in the charging process.
My guess would be that #2 would be the most likely and easiest/least expensive to rectify. There is a light on your notebook somewhere that lights up when you plug it in - is this light coming on when you plug the power adapter in? If not, Then you're looking at most likely option #2 and maybe (but not very likely) #3. If the light does come on, but you still have no power, then most likely your battery is shot and needs to be replaced.
Hope this helps.
Posted on Mar 09, 2009
  • Toshiba Master
  • 32,281 Answers
Your adapter could be faulty, test it with a multimeter, the voltage should be slightly higher than the voltage printed on the label on the adapter.
If the power adapter is OK then the power connector on the laptop could be faulty, plug the connector into the laptop and wriggle the connector to see if the power LED light on the laptop flicks on and off. This indicates a faulty connector and can be repaired.
To check if the laptop is OK, borrow a charged battery or an adapter, connect it to your laptop and see if it boots up.
Sony pcg-81114L power supply not detected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2012 | Sony VAIO PCG-K33 Notebook
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
Battery won't charge even with a new battery
There could be something internally wrong with your laptop. Take it to a reputable dealer to help fix the problem.
Jul 10, 2017 | Toshiba Portege R705-P40 13.3" Notebook PC...
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 10, 2011 | Computers & Internet
VISTA PC DOES NOT STAT laptop vista battery went down to 10% Vista was shut down and was connected to power supply try several times to start the pc but it just does not start if pc is shut does the...
The battery continues to charge if the computer is off. The computer probably won't turn on because the battery is so low. It might not be charging because the power cord might not be plugged into a wall plug that is on. The plug might be on a switch. Find a plug that you know for sure that is on then plug it in there and try again.
Jul 29, 2011 | Computers & Internet
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
Battery not charging . light comes on power supply but batterlife went down even thogh it was plugged in. now now enough power even to start up
Try turning off your computer, removing the battery for 10-20 minutes, put it back in, and turn it on/charge it. If this doesnt work it sounds like a short in either your charging cord or your battery.
If its still under a warranty then send it to your dealer.
Aug 28, 2009 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
