Question about Amana ALG443RAW Gas Dryer
Timer does not move in Auto/delecate
My Amana Dryer ALG443 Raw does not stop as well as timer does not move in Auto/Delacate mode.It stops when I move manually to stop position. Drying is ok in this mode and timid dry. I ran dryer after taking out the feed to blower housing but never solved. I checked the cycling thermostat for continuity and it reads 00.5 ohm resistance. That means I think the thermostat is ok. Any one has answer for this problem. Highly appreciate ur posting.
  • 1 more comment
  • captks Mar 10, 2009
    Thanks,
    My recycle thermostat is mounted on heater thermostat (Bias heater). Both are ok. I understand that if the moisture sensor (two metal strips) is bad the timer willnot advance and stop. Does my model have a sensor if so where can I find it.
    Thanks,
  • captks Mar 11, 2009
    Thank you very much for your kind gesturte and effort to solve the problem. As I was reserching I red a similar problem and a advice to clen the vent. I cleaned the vent this afternoon and good amount of trash got out of it as I never clened the vent after instalation 9 years back. My problem is solved. I would like to rate you 100% for the prompt posting of your solution.
    Guru:
  • 462 Answers
Im guessing there is another thermostat in the circuit to actuate the timer motor circuit. If you can find the timer motor wires check for voltage in the run (cycles yuor having trouble with) modes. Automaticadvance timmer mode is usually an open set of contacts and close when the element is heating too correct temperature allowing power to continue to the timmer motor. In the delicate cycle often it is the same thermostat on a differant set of contacts (but they could be on the same thermostat this type of thermostat has 3 termjinals usually 2 on 1 side and 1 on the other). that energize the timer motor.
The other thing that could be the problem is the timmer itself. There has to be a set of contacts inside the timmer that energize the timer motor in both cycles. these are or can work on some cycles but not others due to worn out parts in the timer. Check for voltages her that corrospond with your timer motor.
Hope this helps Please rate me accordingly and GOOD LUCK
Posted on Mar 09, 2009
  • Farley Redfield
    Farley Redfield Mar 10, 2009
    Yes I did not consider this but it does make sense. Its the same kind of setup except it is depending on direct sensing of the moisture content of your clothes and is probably looking for a specific voltage differance being returnded to the other side of the sensor or maybe even ground. If your inside tub stationary areas are plastic the sensors have to be some kind of metal or composit material to allow the sensing and have to be at 2 points usually in close proximity to each other. If your interior is metal the "pickup" sensor could be a "ground" and this point wouls be any pace the clothes touch the metal and the sensor at the same time, I thinkr for this sensor to work you will have only one point for the output and anyplace around it will pickup the voltage. If it is out of range it may not work at all like the problem your having. Or one of the sensor wires has cracked or fallen off or came apart behind the sensor surface where you cant see it.
    I am not acquainted with the model number however the sensors are usually located on a fixed member of the tub (a part that does nopt turn) either in front or in back of the drum area. If you use a fair amount of fabric softener in the wash its possible that all this sensor needs is cleaning, try some rubbing alcohol (I would suggest finger nail polish remover but it might damage any plastic or cause the sensor to turn loose) on a cloth and cclean the stationary parts inside the dryer.
  • Farley Redfield
    Farley Redfield Mar 14, 2009
    Thank you for your kind rating and comments
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
Dec 11, 2013 | Washing Machines
I have a Amana Dryer NED7200TW. At the end of any drying cycle the dryer shuts off and then turns on again continuously untill i stop it. It also shows a C and a backward C in the display. Any thoughts?
You might need a new display board (electronic timer ). Seems like the timer will not send the message for the dryer to stop when the cloths are dry
Jul 25, 2012 | Amana NED7200TW Electric Dryer
Amana lga30aw. dryer starts in auto mode, pilot on, gas on, goes off after awhile and never comes back on. timer does not move in auto but does move on the timed mode (still does not dry in the timed...
You may need to replace the timer, but watch the video below and it will walk you thru the troubleshooting process. The timer not moving in the "auto sense" mode maybe due to a bad thermostat. Here is a link to the timer in case you need it.
Jan 05, 2011 | Amana ALG331RAW Gas Dryer
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
My Kenmore 80 series dryer won't shut off. It only stops when the door is open. Model #: 110.72822101
In timed mode, the timer has most likely failed and is not advancing. In auto-drying mode, the timer or the moisture sensor has most likely failed.
Apr 05, 2010 | Kenmore Dryers
The timer unit stopped working, it did not move. then the dryer stopped heating also.
HI. The timer device initiates the drying sequence. If the timer motor becomes unstable, it will not close the heater circuit, thus, interrupting the dying cycle. The necessary action will be to have this damaged timer mechanism replaced, asap. Once you have replaced this device, your unit will return to its normal operating status.
Dec 31, 2009 | Amana Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Kenmore gas dryer
is this in the auto mode or timed mode??
Jan 25, 2008 | Whirlpool LGV4634JQ Gas Dryer
Amana ALG443RAW Gas Dryer Logo
258 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
