Question about T-Mobile Dash Smartphone
Dash does not vibrate??? anyone help - T-Mobile Dash Smartphone
  • 4 Answers
It does vibrate! All you have to do is hold down the # button for about 3 seconds and the let it go. The phone will vibrate once, and then it will have the "vibrate" icon at the top of the screen to let you know that it's on vibrate. To turn it off of vibrate, hold down the # again for about 3 seconds. Hope this helps!
Posted on Mar 28, 2009
Vibration in dash of 2005 ford focus
Is it the dash vibrating or is because of wheel vibration? Generally the dash is pretty sturdy and unless its been in a major prang and the panel beaters have missed putting some of the screws back, it shouldn't vibrate. If the vibration starts at a certain speed and the steering wheel vibrates too, I would say its a wheel balance problem. Any Tyre place should be able to rebalance the wheels and sort this out for you. There is a possibility of a drive shaft vibration but im not sure how you check that out. If it is the dash, then good luck... There are many screws, bolts etc that hold the dash together, You will have to by trial and error , see which one is loose or missing. Before you do anything though, check that nothing is loose and rattling or vibrating in your glove box, ashtray or tissue holder. . There used to be this ad on TV showing a Guy who stripped his entire dashboard down to fix an annoying rattle. When he was looking at the hundred parts or so lying on the driveway, he found a couple of spare coins nuts and bolts rattling around in the ashtray which was the cause of the rattle!
Oct 07, 2014 | 2005 Ford Focus ZX4
Clicking sound under dash behind radio area
open fuse box and feel whit your finger whits one is making the cliking sound.problably the one for the blinkers
Jul 07, 2013 | 1998 Jeep Cherokee
Way dose my stearing will vibrat and dash vibrat win i am at a stop
Possibly a misfire, or also check your motor mounts.
Mar 17, 2013 | 2007 Chevrolet Uplander
I have a 2001 Chevy blazer it has a strange vibrating noise behide the gauges when the rpms go up does anyone know why? I also just had my intake manifold gasket replaced ( coolant leak) and the injectors...
from the information you provided, It doesn't sound like anything to do with the work you had done. If the noise sounds like it's coming from behind the dash, it may be a sticky speedometer cable, gets worse in colder weather? Or a loose screw in the dash itself. Check the ashtray for loose change rattling etc, that can get you sometimes ha ha Hope this helps
Jan 03, 2013 | Cars & Trucks
2008 Saab turbo at idle with vibration?
The only thing I can this is a vacuum leak, either a hose or egr valve.
I hope this helps!
Nov 06, 2012 | 2008 Saab 9-3 2.0T
Why does theDashboard vibrates when the heat is
The fan motor is close to the dash and thats coming from the fan motor....prob. the worst when on high...??
Dec 20, 2009 | 1999 Pontiac Grand Prix
2003 Chevy Impala, Driver Side of Dash Vibrating Sound
Do this, when the vibration starts, place your hand over the area and indeed verify the location. Next, check the area for loose anything that'll cause the vibration. Maybe that will help. Good Luck.
Sep 10, 2009 | 2003 Chevrolet Impala
I have a 92 seville and the digital part of the dash doesnt work and all fuses are good.What could be the problem?
The most common problem for this is dry solder joints on the board. You will have to remove the board and examine for cracked/dry solder joints.
They look like this:
http://www.tegger.com/hondafaq/mainrelayoperation/dry-joint_small.jpg
Resolder them and you should be away. They are most common on cars that live on rough or gravel roads, the vibrations create them. In some cases i've heard of people rubber mounting the boards to reduce the vibration.
May 08, 2009 | 1992 Cadillac Seville
My T-Mobile Dash won't vibrate anymore. I didnt use it for a couple of months and when I first started using it again it vibrated but then it just stopped.
Mmm well I don't know if its just a problem with the peice that vibrates for you, but I know that my phone did the same. You can just go into the vibrate settings under the ring type, and edit the vibrate type all to a sound, and then back to a vibrate, and that should fix it. If not it could be internal.
Apr 16, 2009 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
136 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
