Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
Failed to burn DVD disc after 6 attempts. First attempt to do this using Cyberlink Media Show. Error code: 0x0A180001.
Tried 5 different DVD brands (all 16x): Maxell DVD-R, Ativa DVD+R, Memorex DVD+R, Office Depot DVD+R, Panasonic DVD RAM 2X-3X.
Settings: NTSB, High Quality, Drive: HL-DT-STDVD+/-RW GAS-H21N
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Posted on Mar 09, 2009
Cyberlink Power Director 14. Burning Unsuccessful. Error eFF030C00
DVD-R disc probably defective. Source for another make of DVD-R disc and try again.
DVD capacity matters; how many Gigabytes of data can it take/record/accommodate
4Gb
8Gb
Oct 13, 2017 | CyberLink Computers & Internet
I'm attempting to burn a video i created on windows movie maker to a DVD+R 4.7 GB/Go, 1-16x disc. I've attempted burning it straight from the option in windows movie maker, and now I just attempted to use...
If the DVD is unreadable by several devices then the DVD disk was burned wrong and is nothing more than you can do.
Assure that you have a region set on your DVD players and a certified DVD playback software on PC. Windows Media Player 10 should be enough if the disk is still unreadable will remain unreadable and ony speciall software with raw access will read it but this is not a solution for you.
I use Nero 7 for burning CDs and DVDs and never had a problem. Maybe when you burned the DVD you set a wrong regional code or you choosed a wrong DVD format that is unknown to your DVD players.
Nov 02, 2010 | Computers & Internet
ERROR 2131 WHEN ON ITUNES
According to the support page the firmware update fixes the iTunes
issue with “The attempt to burn a disc failed. An unknown error
occurred (2131) when you tried to burn playlist to disc for blank CD-R
media. the region code error for DVD movie playback.
NOTE Please DO NOT USE THIS UPDATE FOR A TOSHIBA LAPTOP the computers
may have the same optical drive but the firmware updates may not be
identical and flashing with the wrong firmware may damage your drive”.
This isn’t just the Toshiba Equium A200 laptop getting an error of
2131, the other notebook’s manufacturers also established the source
of the problem and they have to provide a firmware update to download
and fix this problem. The best thing you can do is wait until Toshiba
provide a firmware update specifically for the TSST TS-L632H version
TO01 drive in your laptop.
Please let me know if you have any fuhrer questions or concerns.
Thanks.
Apr 25, 2010 | Toshiba Satellite Pro L300 Notebook
Cannot write cd/dvds.
The Super Drive needs to be replaced. This error cannot be fixed with software.
If it's still under warranty simply take to an Apple Store, Apple Authorized Service Provider, or contact Apple at 1-800-APL-CARE (1-800-275-2273) or contact an Apple Expert at http://www.apple.com/support/expert/
-=/ Daft Tech /=-
Oct 22, 2009 | Apple MacBook Pro Notebook
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
I cant burn or play dvd
try to burn at a slower speed, turn off the screen saver and virus scanner? if these try to run while a burn is going it can cause an error, try to defrag the hardrive if needed before the burn, try another brand of media , check for software updates on the burning software
Nov 26, 2008 | Optorite (dd0405) DVD±RW Burner
PowerDirector 6- disk type mismatch error???
same thing happened 2 me but with power director 7.0 i need help 2. i worked a total of 5 hours on a movie and i can't burn it. somebody help us!!
May 26, 2008 | CyberLink SW- DVD Software Power DVD...
Cyberlink powerdirector 6 burn error
Latest Drivers:
http://sony.storagesupport.com/dvdrw/dru810adwn.htm#dwns
Try to change the writing speed, sometimes the 16X only 12X!
(I have a 20X writer)
Nov 05, 2007 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Computers & Internet Logo
1,174 people viewed this question
David Payne
David Payne
